Starter Motors,
Posted: Thu Oct 23, 2014 11:56 am
by ian.stewart
Im using a 16v 4Age from a AE86, with a T50 behind it, I don't have the correct starter for this set-up, But I do have a starter from a 16v Mk1 MR2, any problems with this swap?????
Re: Starter Motors,
Posted: Thu Oct 23, 2014 12:33 pm
by yoshimitsuspeed
ian.stewart wrote:Im using a 16v 4Age from a AE86, with a T50 behind it, I don't have the correct starter for this set-up, But I do have a starter from a 16v Mk1 MR2, any problems with this swap?????
All that should matter is intake side or exhaust side.
If it's from the right side it should work. You may have to change the connector on the signal wire.
Re: Starter Motors,
Posted: Thu Oct 23, 2014 2:08 pm
by saiGone
^ yup, other than that, some are missing heat shields (4ac) but you should be fine.
Re: Starter Motors,
Posted: Mon Oct 27, 2014 1:34 pm
by MisterJerk
I have one from an ae92 in mine. works fine.
Re: Starter Motors,
Posted: Sun Nov 09, 2014 11:30 pm
by xarion
In my experience, the only thing you will need in terms of putting the starter at the front or the back is a different cover plate for the gearbox, everything else works as-is.
