Gas on the intake manifold
Rawkstar
Postby Rawkstar » Sat Dec 27, 2014 3:45 pm
Started to get my car up and running after the 16v for 16v swap. Changed out the spark plugs and the coil since it was broken. I start it up and still running sluggish... I mess with the idle a little bit and then I see the gas on the intake manifold. Is it because the injector rings need replacing or do I have a more serious problem?
Re: Gas on the intake manifold
Postby jondee86 » Sat Dec 27, 2014 4:02 pm
Usual reason for a big gas leak on the manifold is either an
O-ring got pinched when you installed the injectors in the rail,
or the O-rings are old and crusty and can't hold pressure. Get
some from an industrial O-ring and seal shop... usually only
a couple bucks for as many as you need.
sirdeuce
Postby sirdeuce » Sat Dec 27, 2014 4:50 pm
Another possible leak is the pulse damper, the piece that bolts the banjo fitting to the fuel rail. But most likely the culprit would be as johndee had stated.
One shot, one kill.
