So here's my dilemma.. I'm looking for an external fuel pump for my stock 20v BT'd 86 and I'm having quite a difficult time... I've heard that you should run between 85 and 115LPH but I can't find anything that uses AN fittings. Is there such a pump or am I going to have to have a custom one made (IF THAT'S EVEN POSSIBLE!!!)?
So far the lowest LPH i've found with AN capabilities was 155LPH but I don't know if that will work properly or not..
Fuel pump dilemma
Re: Fuel pump dilemma
get 155 and adjustable FPR.
problem solved.
problem solved.
- shandangles
155 lph will be fine, or check
https://www.efihardware.com/products/c3 ... t-Fittings
http://www.ebay.com/bhp/fuel-pump-fittings
billions of options
billions of options
High volume doesn't matter as your stock fuel pressure regulator will limit pressure and if you're efi system is working correctly the ecu will adjust the mixture.
If you had a turbo car with big injectors then volume becomes an issue.
Long grain- you can't adjust volume with an adjustable fuel pressure regulator, it adjust pressure only.
Coupe BT 20v #functionoverform
Personally I would go with a Walbro 190 or other similar common size.
You don't want to go much bigger than that on the stock FPR but the 190 will be fine.
