Are there vacuum ports for each throttle that can be used for example a Motion Pro carb synchronizer? I just want to check my 4AGE 20V blacktop's intake.
Re: vacuum ports for carburetor synchronizer?
Posted: Sat Feb 07, 2015 1:02 am
by jondee86
There are no vacuum ports on the ITB's suitable for plugging in your synchronizer. You would need to drill and tap a into the throats somewhere. And as the throttles are "equalised" via the idle air ports and the common vacuum rail, I doubt that the results would be worth the effort. Better to use an airflow meter that plugs into the mouth of the ITB...
Posted: Sat Feb 07, 2015 4:35 am
by choyr
thanks jondee!
Posted: Sat Feb 07, 2015 5:48 am
by PDB
Haha I'm literally using that very tool now to set my carbs on my 16v, it works a treat [emoji106]
Don't think it matters but mine are now pulling around 6 on the meter at idle
