Like the topic says.
What size bolts do I need to mount the block to an engine stand?
Thanks.
Bolt size needed for engine stand
Re: Bolt size needed for engine stand
IDEAL bolts... for the stands I use.... the trailing arm mounting bolts... perfect length.
not sure if they are perfect for you. to determine your "perfect" measure the depth of the engine stand mounts that fit to the block, add 13mm to it (12-15 is ok)
bolt thread is 12 x 1.25
- gotzoom?
USDM front bumper bolts, the ones inside the engine bay, are perfect with a little fender washer shimming
