cam angle sensor or trigger wheel
kp roku ichi
Postby kp roku ichi » Fri Feb 20, 2015 9:20 pm
I have a built 4age 16v and want a COP set up. I also have an formula atlantic cam cover which has a cam sensor on it. Question:
What ignition trigger system does the formula atlantic use? trigger wheel?
What is the use of the cam angle sensor on the atlantic cam cover? Do i still need it even if I'm running webers?
Illegal_Garage
Re: cam angle sensor or trigger wheel
Postby Illegal_Garage » Sat Feb 21, 2015 1:44 am
FA cars use a PECTEL ECU
Max
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
Maxfrommisawa@aol.com
Postby yoshimitsuspeed » Sat Feb 21, 2015 10:28 am
Do you have a picture of this cam sensor?
There have been many iterations of FA so it's hard to make any blanket statements but I would expect any non dizzy version to use a crank angle sensor. This is much more accurate and better than cam angle.
You can see the crank trigger wheel and sensor in this pic.
I hope to have crank pulleys available soon that will have an integrated trigger wheel and a hidden sensor behind the timing cover.
isaactec
Postby isaactec » Sun Feb 22, 2015 7:17 am
on motec, pectel ect.. ecu's to be able to run sequential ignition/fuel you need both cam and crank sensors. the ecu needs to know what cycle the engine is on.
Postby jondee86 » Mon Feb 23, 2015 1:23 am
This ^^^^. The crank sensor provides timing information, and the cam angle
sensor provides a reset to tell the ECU which cylinder to inject or ignite. If you
don't have a cam sensor, the ECU can only batch fire the COP's.
Although in theory batch firing COP's should not work, plenty of people do it
on injected engines and it works. Maybe it will work on a carbed engine, but
I have not tried it and don't know if it will work.
Better to use the cam sensor and then your ECU can run sequential ignition
(four ign outputs required) or wasted spark (two ign outputs required).
