Blacktop Oil Cooler Kit
urzu725
Postby urzu725 » Sat Feb 21, 2015 8:48 am
Hey gang,
I recently read this write-up (http://forums.club4ag.com/zerothread?id=77707) on an aftermarket oil cooler kit.
Will an oil cooler kit for a 16v work with a blacktop 20v? Will the adapters fit for both engines?
Rogue-AE95
Re: Blacktop Oil Cooler Kit
Postby Rogue-AE95 » Sat Feb 21, 2015 3:43 pm
Do you mean the adapter that the oil filter fits onto? Yes it should be the same, since the 16v and 20v blocks have the same mounting points and oil filter location.
Postby MisterJerk » Tue Feb 24, 2015 6:47 am
you will have to take off that crazy looking aluminum tower that the filter is mounted to and mount the adaptor directly to the block. otherwise you will have fitment issues with the header.
