20v OEM valve springs
speedmaster
Postby speedmaster » Mon Mar 02, 2015 2:13 am
How much lift can 20v OEM valve springs take?
jdm86gtz
Re: 20v OEM valve springs
Postby jdm86gtz » Mon Mar 02, 2015 5:44 am
When I bought my AE111 it had Toda 264 9.0mm cams on stock springs. I rebuilt the engine with new Toda springs though.
speedmaster
Postby speedmaster » Mon Mar 02, 2015 10:23 pm
jdm86gtz wrote:When I bought my AE111 it had Toda 264 9.0mm cams on stock springs. I rebuilt the engine with new Toda springs though.
Hello
Did you ever do a dyno test?
THE_ENTHUSIAST
Postby THE_ENTHUSIAST » Thu Mar 12, 2015 11:29 pm
speedmaster wrote:How much lift can 20v OEM valve springs take?
Are you concerned with coil bind or valve float?
It also depends on how aggressive the cam profile is for valve float.
I assume based on this question you are looking at buying some new cams? If so just bite the bullit and get some uprated supertech springs and run which ever cam spec you like.
speedmaster
Postby speedmaster » Sun Mar 15, 2015 7:56 am
just wondering the limit of oem springs
