OBX Plenum for Silvertop
Posted: Sun Jun 14, 2015 6:23 am
by Rulez
Hey all,
I'm new here. I have a 1990 Celica track car with a 4AGE Silvertop swapped into it. I got the car from a friend who raced the car for a long time with the 4AFE in it. He swapped in the ST, but was unable to finish it due to time constraints. Now I have it and I am wrapping it up. I plan to use it for Autox and HPDE events.
I found a hole in the intake plenum. The small vacuum nipple on the back of it looks like it was broken off when the motor was originally pulled. Rather than weld it up, I was looking into an upgrade that was smaller and would clean up the engine bay a bit. I found this plenum on eBay and was curious if anyone had any input on it. I did a search but didn't find anything worthwhile.
http://www.ebay.com/itm/OBX-Turbo-Plenu ... ae&vxp=mtr
Here is the car.
Re: OBX Plenum for Silvertop
Posted: Sun Jun 14, 2015 1:26 pm
by yoshimitsuspeed
The design is about as bad as you could get for a plenum. It's way too narrow and airflow will be compromised.
It looks okay though.
Posted: Sun Jun 14, 2015 3:01 pm
by jondee86
Welcome to club4AG
Rulez wrote:I found this plenum on eBay and was curious if anyone had any input on it.
The OBX plenum you found is for turbo applications, and will not be
helpful for a N.A. car. As it happens the factory plenum actually works
quite well, and of course it has the right size connection for the AFM.
There are aftermarket plenums around... along these lines...
Only they are designed to work best with heavily modified engines with
standalone ECU's. Then the engine can be tuned to take advantage of
the revised intake and conversion to MAP sensing.
Posted: Sun Jun 14, 2015 5:05 pm
by Rulez
Thanks for the input guys! I'll just repair the stock plenum then. Eventually I'd like to go standalone and eliminate the MAF altogether. Better to just invest in that I suppose.
Posted: Sun Jun 14, 2015 8:56 pm
by yoshimitsuspeed
jondee86 wrote:Welcome to club4AG
IMO it's just as awful for turbo applications for the same reasons you would expect it to be for NA.
Posted: Mon Jun 15, 2015 5:11 pm
by moncharleskey
I've been looking at this same hunk of metal myself, trying to decide if it was any better than the one I fabbed from steel. At least I considered how air flows! It's been quite a challenge to find a suitable manifold for my application. Anyone know of any out there for boost applications, other than this junk? At this point I'm considering buying a set of stacks and building a manifold from scratch, but aluminum is an area I haven't gotten in to yet.
Posted: Mon Jun 15, 2015 5:26 pm
by jondee86
The MRP plenum (shown in the pic I posted above) is designed for
boost. The baseplate is CNC'd out of 10 or 12mm plate (can't remember
which right now0 with an o-ring groove for sealing. If you are looking
to boost 30psi you will need something like that
Posted: Mon Jun 15, 2015 5:53 pm
by moncharleskey
Very nice intake too. I'm afraid it would be too wide at the bottom with the supercharger top bracket and coolant pipe in the way. I'll need something that spaces off from the ITBs just enough for bolts to go in. The search goes on!
Posted: Mon Jun 15, 2015 11:33 pm
by yoshimitsuspeed
moncharleskey wrote:Very nice intake too. I'm afraid it would be too wide at the bottom with the supercharger top bracket and coolant pipe in the way. I'll need something that spaces off from the ITBs just enough for bolts to go in. The search goes on!
I can design and make anything you might want but we aren't talking about OBX price range anymore.
You mention supercharger brackets. What exactly are you doing? Supercharged 20v?
Posted: Tue Jun 16, 2015 5:01 am
by moncharleskey
I'm running a 7A block, 20v ST head, and JDM sc12 with 175mm T3 pulley. Loads of other stuff in there too but as far as being applicable to the intake, it's in an MR2 and while my heavy steel one holds the boost, I can't shut the deck lid! I thought about hitting you up to build me one, so shoot me an email if you want to get together on it, this username at Gmail.
Posted: Thu Jun 18, 2015 8:35 am
by oldeskewltoy
moncharleskey wrote:I'm running a 7A block, 20v ST head, and JDM sc12 with 175mm T3 pulley.
I'm not the boost guy... but even I know that poor SC12 is having a tough time... it barely is sufficient for a stock 4AG, now you have much more engine breathing... and still the small charger....
SC14 at the very minimum... but I'd be looking for more volume... look @ Eaton
Now as to running a turbo instead of a S/C... sized right(the turbo), with a good turbo manifold...
and you can make metric tonnes of power
...unfortunately these will fit as well as your intake does...
Posted: Thu Jun 18, 2015 3:38 pm
by jdm86gtz
If you can find a Nissan GTiR intake plenum you could get SamQ's adaptor, they aren't easy find though:
http://www.sq-engineering.com/upgrade-p ... amber.html
