Engine Overhaul Main Bearing HELP!!!
Posted: Wed Aug 19, 2015 5:03 pm
by gerrito225
I have decided to overhaul my engine completely, which was running fantastic. When I dismounted the crankshaft and main bearing, I didn't see if its std or oversize because it only said some numbers and letters. I have taken a picture to help with the problem. The order from the picture from left to right: #1 rod, #5 main, #4 main, #3 main, #2 main and #1 main. Is it ok to just put some std main and rods bearings? Thanksss..
Re: Engine Overhaul Main Bearing HELP!!!
Posted: Thu Aug 20, 2015 5:03 am
by bigbacon
if it was running fantastic, why overhaul it?
Posted: Thu Aug 20, 2015 10:36 am
by gotzoom?
Service manual has the test procedure and spec for the crankshaft journals. That should answer all your questions.
Posted: Wed Aug 26, 2015 12:51 pm
by MisterJerk
link to the fsm in my sig, might have to click around to find it.
Posted: Sun Aug 30, 2015 3:10 pm
by Respeckmejulie
a $20 dial caliper would probably come in handy.. harbor freight sells them...
Posted: Tue Sep 01, 2015 1:20 pm
by gerrito225
bigbacon wrote:if it was running fantastic, why overhaul it?
Just wanted to overhaul it because engine is out and it had 260k miles on it. Want to make sure it last me some good years.
Posted: Tue Sep 01, 2015 1:31 pm
by gerrito225
gotzoom? wrote:Service manual has the test procedure and spec for the crankshaft journals. That should answer all your questions.
I have read the service manual and my question is that the aftermarket bearings arent like the toyota stock ones that each one have a specific number. The aftermarket bearing are std or oversize, is it ok to put the std aftermarket?
