Silvertop/Blacktop valve crossover
Army Fork
Postby Army Fork » Thu Oct 01, 2015 9:34 am
So this is a question Google and many 4A guys I know can't seem to answer, and is fairly simple.
Do the silvertop and blacktop use the same valves? More specifically, can you use a blacktop valve in a silvertop? Do the keepers and springs work? Retainers?
I honestly can't seem to find an answer. If anyone knows, please chime in
Sent from my OnePlus
1984 SR5-GTS 20V ST/BT coupe.
- Stance GR+ Coilovers
- Mishimoto Cooling
- T3 Short shift
- Manual rack conversion
- Blacktop electronics
Re: Silvertop/Blacktop valve crossover
Postby oldeskewltoy » Fri Oct 02, 2015 7:18 am
I've now had 2 silvertop heads and one blacktop head apart....
The physical dimensions of the valves, retainers, spring seats, and keepers are all VERY similar. The valves use the same diameter stems, same diameter seats, same length, and as far as I can see a similar keeper grove at the top. I recently had to use some of my silvertop hardware so I could flow a blacktop head, and it all went together... at least as far as flowbench testing.
Now can you run them ..... that is a different question... maybe... likely.... but it wouldn't be the best solution
Army Fork
Postby Army Fork » Fri Oct 02, 2015 7:23 am
I've actually been directed towards a few different posts that lead me to believe that the valves are effectively identical. At this point I'm pretty certain I can run a mix of valves in my head and the engine will run without issue
- Mishimoto Cooling
- T3 Short shift
Nomnom83
Postby Nomnom83 » Sun Oct 04, 2015 8:34 pm
I am running ae101 valves in my ae111 head and it works fine.
Army Fork
Postby Army Fork » Mon Oct 19, 2015 7:28 pm
I can confirm that it works just fine
- Mishimoto Cooling
- T3 Short shift
