Engine not running 100% HELP!!! (4AGE NOOB)
Posted: Mon Nov 09, 2015 12:53 am
by 4age_lvr
engine started running weird out of the blue
not sure if its a fuel system problem
ignition system prob
ecu
injector prob
I changed the distributor cap and rotor and no changes. Car used to run 100% never had a problem with it, super bummed can't figure it out.
Runs like its got half the power or not really like its bogging.
Engine has good compression.
HELP!!!
Re: Engine not running 100% HELP!!! (4AGE NOOB)
Posted: Mon Nov 09, 2015 10:01 am
by yoshimitsuspeed
Do a full tuneup. plugs, wires, air filter, fuel filter, everything unless it has been done very recently. If so inspect it closely.
While it's ldling pull one spark plug wire at a time. See if the idle drops more on some cylinders than others. If so you have problems with specific cylinders. If not then you have a general problem that's affecting them all.
Start going through the diagnostics and troubleshooting sections of the FSM.
Posted: Mon Nov 09, 2015 7:47 pm
by gts/classic
Pull the complete ignition out check it out thrully...
Posted: Mon Nov 09, 2015 8:44 pm
by sirdeuce
Timing belt?
Posted: Mon Nov 09, 2015 9:23 pm
by jondee86
TVIS stuck open (hose off, solenoid not working etc) ?
Posted: Mon Nov 09, 2015 9:49 pm
by yoshimitsuspeed
sirdeuce wrote:Timing belt?
Wouldn't hurt to check but it should show up on a compression test.
Posted: Tue Nov 10, 2015 10:34 am
by oldeskewltoy
AFM car? Torn intake boot???
