Valvetrain Metal Expansion Compensation?
Posted: Mon Dec 07, 2015 10:56 pm
Hello. Does the subject
Im running 8.6:1 compression being optimistic of a re-tune to 14 psi. with a Garrett GT2560r ( I was tuned to 10 psi. prior to cylinder head removal), with a bigport head equipped with stock valves and Poncams with HKS springs.
When running Tomei Poncams or any aftermarket camshaft in a turbo setup, is it better/safer to run the exhaust valve lifters clearance to the maximum spec? I understand the Fsm calls for 0.20mm- 0.30mm cold, but the Tomei spec sheet calls for 0.25mm... This became a question when i stumbled on a Tacoma 5VZ-FE diy valve clearance topic where the creator said, "the exhaust valves should be set on the loose side, measuring AT LEAST the max clearance (0.37mm for 5VZ-FE), 0.381mm is a good cushion." " Intake valves run much cooler than exhaust valves, so the clearances are less crucial. If an exhaust valve is to tight, it will burn and then you're bummed." Is compensating for metal expansion with the largest clearance on the Fsm's clearance range the optimal setup for longevity, durability, and reliability of the engine's valvetrain? or is this compensation specific to this engine and to this one "mechanic?" http://www.yotatech.com/f128/5vz-fe-3rz-fe-2rz-fe-valve-adjustment-tech-226997/
I don't want to run the risk of a burnt valve or tapping because I exceeded either end of the Fsm's valve lifter clearance, assuming the Fsm's range is acceptable in a higher heat forced induction setup with the use of an aftermarket camshaft. I planned on setting the clearances to 0.25mm on the exhaust side, which is what Tomei calls for with use of the Poncam. Coincidentally, that clearance is right in the middle of the range the Fsm specifies for stock camshafts. This led me to assume a clearance of 0.25mm +/-0.01mm will suffice, till I read the topic for the 5VZ-FE. It makes sense that compensating for metal expansion is more of an issue for exhaust valves compared to the intake valves since they are the ones seeing all the heat on the exhaust stroke, but does the 4age have its own rules to go by? Do I have a cushion?
Perhaps there is someone who can provide guidance, based off of their own experience and expertise. Thank you in advance to those who choose to reply to this topic. I look forward to your insight.
