Car is turning but won't start. Please help
Bideogame
Postby Bideogame » Sat Apr 16, 2016 12:43 pm
I have an 85 gts that will turn but won't start. Could the idle be the problem? How do I fix it at home without taking it to the shop, cause money is kinda tight right now. Any help is appreciated!! Thank you!
demby123
Re: Car is turning but won't start. Please help
Postby demby123 » Sat Apr 16, 2016 4:47 pm
Spark ok? Fuel delivery/pressure ok?
Bideogame
Postby Bideogame » Tue Apr 19, 2016 11:17 am
No spark. Thinking it's the ignitor. Don't have 200 for a new one :(
Postby jondee86 » Tue Apr 19, 2016 2:53 pm
Did you check to see if you have 12V at the coil positive connection when the key is ON ?
The igniter is a fairly tough little critter, and they don't usually die without a good reason.
P3nnyw1se
Postby P3nnyw1se » Sun May 01, 2016 3:27 pm
Yeah. Measure the voltage there and be sure that's not it. Was it running fine before?
