rhd ae86 20v velocity stack length
Posted: Wed Jun 08, 2016 11:59 am
Hi guys,
I have a RHD 86 Levin, planning to swap in a BT 20V motor.
I'm trying to figure out what's the best way to run velocity stacks on this car.
I heard the max I can run is 70mm or 50mm with an individual filter? Due to clearance issue with the brake booster on RHD.
But that would cause too much power loss.
http://www.outerwearsracing.com/products.asp?cat=12675
i was also looking at these, it's very low profile, but not sure how good the flow is.
so i have 2 questions
rhd ae86 bt 20v
1. Assuming I will run without filter, what's the longest velocity stack i can fit?
2. If i want to run a filter, what's the best option to fit the longest velocity stack?
Thanks !!
rhd ae86 bt 20v
Thanks !!
