AE101 4AGE Distributor
BlueAngel
Postby BlueAngel » Mon Jul 11, 2016 10:58 pm
Hello!!
I am looking for some assistance, perhaps some of you may have gone through this issue already.
Can any of you tell me, what is the OEM part number for a 1991 AE101 Silver Top 4AGE Distributor?
We pull mine out but the sticker with the part number is unreadable and I can't find anything close to match the distributor.
Any help will be greatly appreciated.
Thank you
GZE_RA21
Re: AE101 4AGE Distributor
Postby GZE_RA21 » Tue Jul 12, 2016 5:27 pm
19100-16270
Google is a magical thing, took me 60 seconds to find the p/n and another 60 seconds to cross reference and find out the distributor is apparently the same between the silvertop and blacktop.
Postby jondee86 » Tue Jul 12, 2016 10:04 pm
Part 19100-16270 (DISTRIBUTOR ASSY) was found on the following models:
Market Date range Model Frames/Options Found in diagram
Japan 06/1991-05/2002 TOYOTA COROLLA AE10*,CE10*,EE10* 19-02: DISTRIBUTOR
Japan 05/1995-07/2000 TOYOTA COROLLA AE11*,CE11*,EE111 19-02: DISTRIBUTOR
General 08/1991-10/2001 TOYOTA COROLLA AE10*,CE100,EE10* 19-02: DISTRIBUTOR
Japan 06/1991-05/2002 TOYOTA SPRINTER AE10*,CE10*,EE10* 19-02: DISTRIBUTOR
Japan 05/1995-07/2000 TOYOTA SPRINTER AE11*,CE11*,EE111 19-02: DISTRIBUTOR
Japan 06/1991-07/1998 TOYOTA LVN AE10* 19-02: DISTRIBUTOR
Japan 05/1995-07/2000 TOYOTA LEVIN, TRUENO AE11* 19-02: DISTRIBUTOR
Japan 08/1995-06/2002 TOYOTA SPRINTER CARIB AE11* 19-02: DISTRIBUTOR
Japan 08/1996-11/2001 TOYOTA CARINA FF AT21*,CT21*,ST215 19-02: DISTRIBUTOR
As neither the AE101 or AE111 was sold in the US, you will have to try one of the
businesses that import used engines/parts from Japan, or chance your luck on
Ebay/Toyota forums.
BlueAngel
Postby BlueAngel » Thu Jul 21, 2016 9:38 am
GZE_RA21 and Jondee86
Thank you very much to both of you for your help.
Seems like both of you are very experienced with the 4AG engines. I am not as good and the dealers around me trying to help are unfortunately useless, as they keep claiming the part numbers for this vehicle are not in their system because is an imported engine.
It turns out to be the distrubutor housing, without the distributor cap and without the rotor. But they cannot locate those parts. I have tried several websites and they show the same picture for different models with different part numbers, so I'm not sure which one to order.
The dealer ordered a 19235-16270 and turned out to be wrong.
Perhaps, you guys can help me narrow it to the correct one.
I wish I can upload some pictures but the system keeps telling me the file is too large.
I could send it to you directly if you provide me an email.
Thank you in advance for you support.
morgan
Postby morgan » Thu Jul 21, 2016 11:45 am
19235-16060
My turd of an 86
20v swapped 86 write-up
BlueAngel
Postby BlueAngel » Fri Jul 22, 2016 7:32 am
Thank you Morgan.. :)
Users browsing this forum: No registered users and 12 guests
