I have a 20v silvertop m/t ecu and the center transistor is burned out. Could anyone check to see if they have the part number for the transistor. My pictures include the part number for the ecu. I also have the notorious leaking capacitors but I can fix those no problem. I just don't know what to replace the transistor with. Thanks for any help in advance. I did spend weeks researching the issues with 20v transplants and thanks to this board I knew I had bad capacitors before I opened the ecu. I was surprised to see the bad transistor. According to what I have read it is more common in a blacktop ecu.
