20v blacktop o2 sensor
GZE_RA21
Postby GZE_RA21 » Sat Aug 20, 2016 1:06 pm
Hi! Just wanted to run a quick one by you guys, I have a 20v blacktop in my gts corolla and was wondering if anyone had ever tried using a different o2 sensor than the factory blacktop sensor? (89465-19685)
I ask because it's like $100+ for the oem BT o2. I found and ordered an o2 sensor for a 1995 3.0 v6 4runner because it looks the same and has the same connector, most importantly a denso sensor was only $40 shipped.
I hooked it all up and installed it and it hasn't thrown a code and seems to be functioning. (My engine was missing the o2 when I got it and was running horribly rich)
Anyone else have any input? Ive never seen anyone else try this before and figured if it works it might be a helpful alternative.
Re: 20v blacktop o2 sensor
Postby totta crolla » Sat Aug 20, 2016 1:31 pm
No reason why it should be a problem as long as the connections are correct.
bigbacon
Postby bigbacon » Sat Aug 20, 2016 2:12 pm
i have a MR2 and i use an el cheapo 16v replacement O2 sensor with my BT with no bad side effects.
s24a
Postby s24a » Sat Aug 20, 2016 2:29 pm
The only requirement I know of for the sensor is to make sure the heater resistance is around 11 to 16 Ohms so as to not tax the drive transistor of the O2 heater circuit. Other than that, you can use any zirconia sensor with a heater (preferably four-wire) and a connector that matches your harness or a connector with a harness connector change if you like.
I think my sensor is from an early 90s Dodge Neon....
Hank
morgan
Postby morgan » Tue Aug 23, 2016 7:02 am
pretty much any 90s Toyota O2 sensor works. ive had great results with one from an mr2 with the 3sgte
My turd of an 86
20v swapped 86 write-up
