20v blacktop itb alpha-n haltech
AlpineFD
Postby AlpineFD » Mon Aug 22, 2016 7:38 pm
Hello !
I bought a Haltech Sprint 500 and looking to install this in a AE86 with 20v blacktop swap.
I'm planning to use a fairly aggressive cam (Kelford Type C), so I've heard the map signal will not be accurate, and we should tune
using Alpha-N
Does anyone have information on how to setup Alpha-N on Haltech?
Any Haltech tips for my setup will be greatly appreciated.
Toyota 4age 20v blacktop
Individual coil on plug conversion (toyota 1nz-fe coil)
ITB open velocity stack
o2 wideband sensor (Innovate MTX-L)
Re: 20v blacktop itb alpha-n haltech
Postby jondee86 » Mon Aug 22, 2016 11:24 pm
From the Haltech website blurb for the Platinum Sprint 500...
TYPICAL APPLICATIONS:
• 1 to 8 Cylinder engines
• Normally Aspirated or forced induction
• Load sensing by throttle position or manifold pressure (MAP)
• Sequential, semi-sequential, batch or multi-point injection patterns
• Distributor ignition systems or multi-coil systems
Alpha-N is another way of describing an ECU that uses the TPS as the primary
load sensor, and the fuel/ignition maps use TPS angle (alpha) vs engine rpm
(N) as the axes. The above quote indicates that this should be selectable in
the software when you are setting up the ECU parameters.
The setup procedure will be covered in some detail in the manual that you
will have received with the ECU.
BattleGarage_RS
Postby BattleGarage_RS » Mon Aug 29, 2016 6:43 pm
Is this a Battle Garage kit? We have a new Alpha-N map that is available to current customers.
If so, please shoot us an email.
Grant
