Please help - what are these and where do they go?
Posted: Wed Oct 05, 2016 4:32 am
Hi,
I'm finally putting my 4age in my MR2 mk1 back together, and there's a few electrical bits I'm not sure where to install.
Image 1
https://postimg.org/image/owyl5dcpp/
Where does this bugger go? I assume somewhere near the alternator? I have two connections like this one. One is one the water temp sender, and I have connected the connector with the rubber sleeve to it. But I don't know where this other one goes. There's another connector that fits it near the one that with the rubber sleeve that connects to the water temp sender
Image 2
https://postimg.org/image/m23glu0cf/
Where exactly do I connect these ground points (MR2 mk1) (I know 1 goes to cylinder head, where the engine lifting hook is, the other one goes below the coolant filler neck bolt, but I have no idea where the third one goes).
Much appreciated thank you.
Image 1
Image 2
