Check engine light at high RPM
kevinmetal
Postby kevinmetal » Wed Apr 05, 2017 5:04 pm
I have a 85 GT-S with stock 16v and I'm getting a code 4- water temp sensor at about 5-6k and it will stay on while driving until I come to a stop and then the light will go away. Car will still run fine with no issues. I see 3 sensors together on the thermostat housing, I know the middle one is for the gauge, but I'm not sure which of the other 2 are for the ecu?
Re: Check engine light at high RPM
Postby jondee86 » Tue Apr 11, 2017 10:14 pm
There are two sensors besides the gauge sensor. The green one is the ECU water temp sensor.
The brown one is the cold start injector time switch. The time switch does not have anything
to do with the ECU. It just gets power during cranking, and if the engine is cool enough it will
activate the cold start injector.
So check the plug is tight and sitting properly on the green sensor, and check the wires for any
signs of corrosion or internal breakage due to the wires flexing for 30 years :)
