Wiring blacktop to fire up
saigon
Postby saigon » Wed Jun 21, 2017 10:33 am
Ok I taught I had everything figured out but doubting myself just need a simple wiring drawing to try and fire it up what wires to just make the the engine fire up all my plugs r in place engine turns over with my push button now need spark and fuel info help thanks
morgan
Re: Wiring blacktop to fire up
Postby morgan » Wed Jun 21, 2017 1:51 pm
have you looked thru the DIY section?
viewtopic.php?f=28&t=4906
scroll down to the "T" & "C*" plugs
My turd of an 86
20v swapped 86 write-up
saigon
Postby saigon » Wed Jun 21, 2017 3:23 pm
Yes just confused I have a wire from coil and one igniter don't know where to connect ( hot or ground don't know ) and the rest I think is in the right place ecu wires r conected starter is connected I can turn engine over but no spark yet .
morgan
Postby morgan » Fri Jun 23, 2017 9:56 am
well theres a link to another site in that thread that has the pin-outs for every connector, plus the wiring section has it all laid out as well. it should be easy to figure out the wires in question
My turd of an 86
saigon
Postby saigon » Fri Jun 23, 2017 1:50 pm
Just checking the sensor under coil has a blk w wire and a white wire coil and igniter hooked to get 12v but what is the white wire ( ground )?????
