Another Timing Issue...
Posted: Wed Feb 13, 2013 3:58 am
Okay so this one is a bit different, or its just that I cant find anything on the same problem...
The vehicle is an AE86, however regardless of this problem... It is powered by a 16 Valve Bigport with Cams, Cam Gears, ITB's, blah blah. Originally it was running the standard ECU and an SAFC for the throttles and big injectors, but running like a pig and had 50 degrees of advanced timing to make it run, however startup was not easy... At this stage it made 89 Hp on the dyno and we discovered timing was retarding instead of advancing ( Hence all the Timing added in). I had the same problem with another 16V of mine which turned out to be an incorrectly set TPS. In this case the SAFC didn't get a TPS reading and suspected the ECU didn't either. At this stage we decided to get rid of the SAFC **** and went to MoTeC, twin coils and a dual output igniter. At least now we can see the timing mark but the timing still goes backwards, if we lock the ECU at 20 degrees, theoretically it shouldn't move at all, nek minnit timing retards to about 5 degrees after. Which leaves one thing - Somewhere, somehow the engine is mechanically retarding the timing. So I volunteered to make the 400+ KM round trip to my old folks place and grabbed my dizzy from my 16V to see if it was a sensor problem, put it in and rewired to suit MoTeC, still the same problem. I'd suspected it could have had a sheared keyway on the crank but that wouldn't give a consistent retard upon revs...
Can anyone share an opinion as to what it could be?
Thanks, Aidan
Thanks, Aidan
