Oil port?
greghotz
Oil port?
Postby greghotz » Fri Nov 09, 2018 11:29 am
On the drivers side of the 4A block, just below the front freeze plug yhrre,are 2 ports in the block. One towards the front is the oil pressure sender port, the other has a plug in it. What is it for? If it is also a oil port I'd like to use it for oil temp. Any ideas?
thanks
morgan
Re: Oil port?
Postby morgan » Fri Nov 09, 2018 11:40 am
plug is for coolant drain
My turd of an 86
20v swapped 86 write-up
Rogue-AE95
Re: Oil port?
Postby Rogue-AE95 » Fri Nov 09, 2018 6:07 pm
Some blocks have just a plug in that drain port, and some (AW11 for one) have a fancy draincock that you can attach a small hose to help keep the coolant from spilling all over.
'88 Corolla All-Trac
Users browsing this forum: No registered users and 16 guests
