Had this left over after assembling my blacktop, what is it and where does it go? Thanks
http://www.saacforum.com/gallery/8-081119102407.jpeg
sensor/sender
Re: sensor/sender
looks like an oil pressure sender, should go somewhere near the oil filter.
Re: sensor/sender
Re: sensor/sender
Thats the Knock Sensor, screws into the block, centered under the intake.
theres a pic here, scroll down a few comments...
http://forums.toyspeed.org.nz/viewtopic.php?f=3&t=92798
My turd of an 86
20v swapped 86 write-up
My turd of an 86
Re: sensor/sender
morgan wrote:Thats the Knock Sensor, screws into the block, centered under the intake.
Re: sensor/sender
Got it, Thank you!
Re: sensor/sender
oldeskewltoy wrote:morgan wrote:Thats the Knock Sensor, screws into the block, centered under the intake.
ha... I believe you are correct... I wasn't 100% sure, just assumed.......
it looks a lot like the aw11 oil pressure sensor
My turd of an 86
My turd of an 86
