sensor/sender
tlea
sensor/sender
Postby tlea » Fri Nov 08, 2019 9:18 am
Had this left over after assembling my blacktop, what is it and where does it go? Thanks
http://www.saacforum.com/gallery/8-081119102407.jpeg
aukword1
Re: sensor/sender
Postby aukword1 » Fri Nov 08, 2019 9:24 am
looks like an oil pressure sender, should go somewhere near the oil filter.
Re: sensor/sender
Postby oldeskewltoy » Fri Nov 08, 2019 10:30 am
morgan
Re: sensor/sender
Postby morgan » Fri Nov 08, 2019 12:11 pm
Thats the Knock Sensor, screws into the block, centered under the intake.
theres a pic here, scroll down a few comments...
http://forums.toyspeed.org.nz/viewtopic.php?f=3&t=92798
My turd of an 86
20v swapped 86 write-up
Re: sensor/sender
Postby oldeskewltoy » Fri Nov 08, 2019 2:26 pm
morgan wrote:Thats the Knock Sensor, screws into the block, centered under the intake.
:shock: ha... I believe you are correct... I wasn't 100% sure, just assumed.......
tlea
Re: sensor/sender
Postby tlea » Tue Nov 12, 2019 4:26 am
Got it, Thank you!
morgan
Re: sensor/sender
Postby morgan » Tue Nov 12, 2019 11:23 am
it looks a lot like the aw11 oil pressure sensor
My turd of an 86
Users browsing this forum: No registered users and 17 guests
