Early 4AGZE Pistons what rings am I supposed to use?
mk1spyder
Postby mk1spyder » Mon Mar 16, 2020 4:49 pm
So I am building a 4AGZE engine and I got my hands on an early NOS set of 8.0:1 pistons for a big port engine. But I see the Toyota rings are discontinued and there is nothing on rockauto, ebay provides some el cheapo rings but I don't trust them. They are standard 81mm pistons, I know the early 4AGE rings are technically the same size but why do they have a different part number from the 4AGZE rings? I would imagine there is a strength difference in the metal composition. So what is the best option for a high boost engine?
Davegt27
Re: Early 4AGZE Pistons what rings am I supposed to use?
Postby Davegt27 » Tue Mar 17, 2020 12:08 am
try 13011-16090 (I think that is the GZE ring set part number) I wrote standard, stock on the box
you might be able to call total seal and ask if there is a difference
http://015ef8d.netsolhost.com/SearchByApplication.aspx
Davegt27 Code One Racing
mk1spyder
Postby mk1spyder » Thu Mar 19, 2020 11:09 am
That part number is for the newer pistons. I need the 1.5mm top ring set. Total seal discontinued them.
mk1spyder
Postby mk1spyder » Thu Mar 19, 2020 11:12 am
Just kidding 13011-16090 is the correct part# now I just have to find some.
