Page 1 of 2
20v bt not starting
Posted: Tue Feb 19, 2013 12:33 pm
by v33sonata
1st let me say I dint know the flames were coming out unti lI just saw the vid. But got a tweeked wiring harness with COP conv. I'm getting fuel and now seeing the flames I am guessing spark as well. Any suggestions?
Re: 20v bt not starting
Posted: Tue Feb 19, 2013 3:44 pm
by Army Fork
If you're running a COP conversion your also running wasted spark, which is why you're getting flames out the intake, the spark on one intake is firing before the fuel charge enters the chamber. Your timing is too advanced, it's not firing at TDC. You have to retard (Hopefully I'm using 'retard' and 'advance' in the proper way, sure I'll get corrected otherwise) the ignition timing by turning the dizzy.
This may have to do with how the coils on the COP's charge compared to how the normal 20V coil charges, which may be why it's not starting because the timing is wrong for the different charge time. You should be fine if you just adjust the timing.
Posted: Tue Feb 19, 2013 4:03 pm
by v33sonata
Army Fork wrote:If you're running a COP conversion your also running wasted spark, which is why you're getting flames out the intake, the spark on one intake is firing before the fuel charge enters the chamber. Your timing is too advanced, it's not firing at TDC. You have to retard (Hopefully I'm using 'retard' and 'advance' in the proper way, sure I'll get corrected otherwise) the ignition timing by turning the dizzy.
I was jsut messing with that and still nothing. However I am just moving and starting as I have no reffreance is to where its suposed to be
Posted: Tue Feb 19, 2013 4:18 pm
by Army Fork
Well your timing is definitely off, but that could be masking other problems. Pull your plugs and make sure they're clean, check your wires and make sure that everything is connected correctly. You may not be firing all four plugs
Posted: Wed Feb 20, 2013 9:35 am
by v33sonata
Army Fork wrote:Well your timing is definitely off, but that could be masking other problems. Pull your plugs and make sure they're clean, check your wires and make sure that everything is connected correctly. You may not be firing all four plugs
Nothing! I'm gonna check for spart today altho I am sure I am getting it. Does anyone have a timing belt diagram for the 20v BT?
Posted: Wed Feb 20, 2013 12:11 pm
by MisterJerk
here's a link to morgan's DIY valve seal replacement on BT 20v.... The timing part is what you need.
http://www.shiftgearblog.com/2011/06/di ... e-20v.htmlIf i can find the link for the 20v engine FSM i will edit it in for you. here it is.... ignition section, IG-9
http://www.locost7.info/mirror/4age_blacktop.php
Posted: Wed Feb 20, 2013 4:59 pm
by xb_release_2
My guess is timing is off. The stock 20v ecu is very picky and all it's vital sensors plugged in and working.
Posted: Wed Feb 20, 2013 6:19 pm
by v33sonata
Thanks for the link! The timing marks line up. I did do a Compression test today and got 50, 95, 96 and 97psi I guess spec min is 150ish. But I think my batt was dieing. I am recharging and going to take another shot. I also checked and am getting spark in all 4 spark plugs. Any other suggestions guys?
Posted: Wed Feb 20, 2013 7:09 pm
by xb_release_2
Check to see if your injectors are squirting, As well
Posted: Wed Feb 20, 2013 10:45 pm
by Army Fork
I'd say that's unlikely with the fire out the intake, and if you're running on all four for spark then I'd say it has to be the cam timing, or at least that's what me and my mechanic buddy are thinking. I dunno man, ****'s weird. It might also be that you're not fueling properly, could explain why the flameout is so sporadic. Run some injector cleaner, I doubt it's the fuel but at this point all avenues are worth exploring.
Posted: Thu Feb 21, 2013 12:06 am
by runkillerrabbit
yea black top is very picky with its inputs. did you replace any sensors?
Posted: Thu Feb 21, 2013 6:19 am
by MisterJerk
might show a little low on the comp test since the engine is cold. dont forget to open the throttles all the way when you do the comp test. (i know you knew that, but sometimes silly stuff can thwart the whole mission) Plus, if the engine has been sitting(not running) for awhile the injectors can get gummed up and stick. I tapped mine with a screw driver handle and unstuck them before. at one point i got a set of used injectors and ended up running power to them, one at a time and blasting carb cleaner through them.
Trying to figure **** out like this is a humongous PITA. Good luck and I hope this ish gets sorted soon.
Posted: Thu Feb 21, 2013 8:43 am
by allencr
Low compression = cam timing is off.
#1 probably has some smegma on the seat & will be OK next time or else it's F'd.
Posted: Thu Feb 21, 2013 8:50 am
by v33sonata
Army Fork wrote:I'd say that's unlikely with the fire out the intake, and if you're running on all four for spark then I'd say it has to be the cam timing, or at least that's what me and my mechanic buddy are thinking. I dunno man, ****'s weird. It might also be that you're not fueling properly, could explain why the flameout is so sporadic. Run some injector cleaner, I doubt it's the fuel but at this point all avenues are worth exploring.
This thing is driving me nuts! The only thing I might be able to think is maybe the harness is messed up. Tweak'd and I goign to do some troubleshooting monday. Hopefully this will help.
Posted: Thu Feb 21, 2013 9:06 am
by Army Fork
I think Allencer is right about the timing, we had the same thought on my end independently. Check your cams, make sure they're set properly.
Posted: Fri Feb 22, 2013 8:48 am
by runkillerrabbit
yea thats timing for sure. and its your flooded cylinders catching on fire. atleast you have spark. and injectors work. id start with a some white out, remote starter and timing gun. and check all the little notches to factory specs and go at it. ooo and one place you should check is your exhaust. my friends old mustang had similar problem there was a dead rat in the exhaust. plugging it.
Posted: Fri Feb 22, 2013 5:28 pm
by Army Fork
Dead rat in the exhaust, my christ. Maybe Jeremy Clarkson shoved some fruit in it.
Posted: Sun Feb 24, 2013 6:06 am
by v33sonata
runkillerrabbit wrote:yea thats timing for sure. and its your flooded cylinders catching on fire. atleast you have spark. and injectors work. id start with a some white out, remote starter and timing gun. and check all the little notches to factory specs and go at it. ooo and one place you should check is your exhaust. my friends old mustang had similar problem there was a dead rat in the exhaust. plugging it.
Wow! lol
Posted: Mon Feb 25, 2013 10:26 am
by v33sonata
Some light at the end of the tunnle! After not being able to get ahold of tweak'd today I decided to just start without them. Time, check, spark, check, fuel, chec.......wait a second. Tweak'd wired my harness backwards. I was able to squeeze enought out of the wires to make them switch to the opiset ones and she fired up. However it sounds like crap. Here is a vid. Keep in mine it was on for a matter of seconds before the vid started.
Posted: Mon Feb 25, 2013 10:56 am
by runkillerrabbit
yea i dont have good experience with dr tweak either. i got a dr tweark blue top to black top conversion harness couldnt get it started! so i just went standalone.
i paid 900 bucks too. i do everything to the dime. i dont mickey mouse anytrhing.
never trusting tweak for a harness again.
Posted: Mon Feb 25, 2013 11:03 am
by runkillerrabbit
dude i think timing is off bthat knocking noise sounds like the piston hitting a valve. thats not good.
are you doing everything fsm says to set timing? line up all the hash marks? crank pully to oil pump mark, cams, etc
page em-10 on the black top fsm
link below
http://www.locost7.info/files/engine/4a ... bt4-em.pdf
Posted: Mon Feb 25, 2013 1:25 pm
by v33sonata
runkillerrabbit wrote:dude i think timing is off bthat knocking noise sounds like the piston hitting a valve. thats not good.
link below
Timing is dead on.
Posted: Mon Feb 25, 2013 1:35 pm
by Army Fork
Could be a bad injector, dunno. Waiting on my mechanic friend to take a listen
Posted: Mon Feb 25, 2013 3:04 pm
by v33sonata
Ya my tech friebnd said the same thing. Here are some more. However it isnt looking good
Tried to go around the block and the car has zero power also!
Posted: Mon Feb 25, 2013 3:09 pm
by Army Fork
Check out your injectors, and please don't try to drive the car until the engine is repaired. It probably won't hurt it, but putting a malfunctioning engine under load isn't something I'd recommend
Posted: Mon Feb 25, 2013 3:16 pm
by v33sonata
Army Fork wrote:Check out your injectors, and please don't try to drive the car until the engine is repaired. It probably won't hurt it, but putting a malfunctioning engine under load isn't something I'd recommend
No i'm not I literly tried to take it out of the driveway and got about 5 feet and said...nope this isnt working haha
Posted: Tue Feb 26, 2013 4:58 pm
by Army Fork
So I had my mechanic friend listen, and it isn't good news. There is some part in your engine striking another part, you could have a spun rod bearing or you may have a problem with your wrist pin. Obviously we can't know for sure, but that engine sounds like it needs to be torn down, inspected and rebuilt because that is not an injection issue.
Posted: Tue Feb 26, 2013 9:05 pm
by v33sonata
Army Fork wrote:So I had my mechanic friend listen, and it isn't good news. There is some part in your engine striking another part, you could have a spun rod bearing or you may have a problem with your wrist pin. Obviously we can't know for sure, but that engine sounds like it needs to be torn down, inspected and rebuilt because that is not an injection issue.
Thanks for the reply. Ya my guess was rod knock. I am working with the place I got it from to see if there is something they can do before I tear it down.
Posted: Fri Mar 01, 2013 9:24 am
by Army Fork
Good luck dude
Posted: Sun Mar 03, 2013 6:39 am
by v33sonata
Thanks. SO a tech buddy of mine looked at it he thinks its a bent valve. I gonna take the head off todya and figure it out.
