Need to figure out wiring for 22R/5M ignitor to use on my 16V 4AGE
Posted: Thu Nov 26, 2020 8:50 pm
I am using a coil/igniter combo off of a 5M / 22R engine, specific part number 90919-02106
This setup was working with my 4AGE but with a different ECU (off a Mazda 323 Turbo). From the research I have been doing, these are what the wires off the igniter are for:
BROWN - To Coil +
BLACK - To Coil -
RED - To Dizzy Pickup + Wire
WHITE - To Dizzy Pickup - Wire
YELLOW - Tach Connection
Previously with the Mazda 323 ECU, the red and white wires off the igniter were connected to the red and white wires off the distributor plug. The brown wire is wired to the ignition and the black wire went to that ECU's ignition signal pin, which is only one pin.
I have now sourced the proper 4AGE OEM ECU and after wiring it up, I get no spark. This is how I have it wired to the 4AGE ECU.
IGNITER:
BROWN - To Coil + (and +12V IGNITION)
BLACK - To Coil - (and NE on ECU)
RED - To Dizzy Pickup + (IGT on ECU)
WHITE - To Dizzy Pickup - (IGF on ECU)
DISTRIBUTOR
RED + Wire (G+ on ECU)
WHITE - Wire (G- on ECU)
Has anyone done this mod? Do I have the wiring wrong? Are there other things I need to check for the coil and igniter to work? (for example, i checked the ground points, fuel injectors and AFM are wired up). I am getting no spark with how it's wired.
I've added pictures for reference:
BROWN - To Coil +
BLACK - To Coil -
IGNITER:
DISTRIBUTOR
