Silvertop loosing power while driving..
Posted: Thu Jan 13, 2022 11:02 am
I need help from the Silvertop 4AG experts in this forum. this is my situation.
I replaced the sender unit to correct the inaccurate reading in the instrument cluster. few days after the replacement, the FX now lose power while driving, the car start shaking and dies. this is very dangerous because it happened several time in the hwy and I was about to get rear ended.
when that happened, I have to try several times to crank it, at times it cranks but with a very low RPMs making a noise as if it getting limited fuel.
I would like to replace the fuel pump, the fuel filter, the distributor cap, and spark plugs cables, but I cannot find part numbers.
I already got the spark plugs and the distributor rotor.
Do you guys have any idea what could be causing this issue? the engine it's installed in a AE82 Corolla FX.
Please help.
thank you all in advance.
Please help.
