Anyone knows the name of this hose and the part #?
s3cf
Postby s3cf » Sun Mar 27, 2022 12:05 pm
Please see picture/link, circled in red, thanks
https://imgur.com/a/tzPm1b6
davew7
Re: Anyone knows the name of this hose and the part #?
Postby davew7 » Mon Mar 28, 2022 5:19 am
That hose is for venting the crankcase gases. The 4AGE hose dose not have a PVC valve in it. [Positive Ventated Crankcase.]
It is not a special hose! Any hose with a tight fitting ID can be used as a replacement.
s3cf
Postby s3cf » Mon Mar 28, 2022 9:33 am
^^^^ thanks!
Rogue-AE95
Postby Rogue-AE95 » Sun Apr 10, 2022 9:06 pm
davew7 wrote:That hose is for venting the crankcase gases. The 4AGE hose dose not have a PVC valve in it. [Positive Ventated Crankcase.]
Does air ever get pulled into the head through that hose? Just wondering, as the 4A-FE has a PCV valve there.
davew7
Postby davew7 » Mon Apr 11, 2022 6:02 am
Yes, the air from the engine cam cover enters the intake throught the hose. The 4AGE only has baffles in the cam cover and no PVC. That is why you see some cars that auto-cross during hard cornering have a puff of smoke from the exhaust, because the intake just got some oil sucked in from cam cover on a RH turn. The fix is to run a longer hose to a catch can, then a return back to the intake.
Rogue-AE95
Postby Rogue-AE95 » Thu Apr 28, 2022 12:10 pm
I suppose it's better to have the return hose running from the catch can to the intake, than to just plug up the fitting on the intake and vent the catch can? Like the intake is drawing air out of the crankcase, which is necessary?
Postby jondee86 » Thu Apr 28, 2022 2:34 pm
viewtopic.php?f=9&t=12011
