Early T50 shifter questions
Posted: Mon Feb 25, 2013 9:32 am
by seanb
So im working on an engine swap into a non toyata car. Im gonna be using a GTS 4AGE with a T50, but im using an early tail shaft and shifter to move the shifter closer to the engine. I all ready have everything put together, but i have some slop in the shifter. i have narrowed it down to the ball of the shifter rod. I had bought the entire T50 from a 1975 Corolla, just to get the linkage and tailshaft. The box was roached though, so my question... is there sopposed to be a bushing where i got the arrows pointing?
Heres the box assembled
Re: Early T50 shifter questions
Posted: Mon Feb 25, 2013 12:26 pm
by ga_goosh
here is the link to this gear box from http://www.toyodiy.com and it does not look like there is a bushing there. there looks to be a shifter return ball and a spring that may be worn outho. there is also a shifter return spring that could be worn out too. there is also a return spring seat that could be plastic and gone. if you cant see the pic create an account on toyodiy and log in and then you will see the pic.
33258A SPRING, SELECT RETURN
90501-14583 1 $2.06
33255C SPRING, SELECT RETURN PLATE BALL
90501-16041 1 $2.13
33255B BALL, SELECT RETURN PLATE
90360-10003 1 $1.34
33258 SEAT, SELECT RETURN SPRING
33258-14010 2 $3.16
http://www.toyodiy.com/parts/p_U_1975_TOYOTA_COROLLA_TE37L-MDA_3312.html
Posted: Mon Feb 25, 2013 2:24 pm
by seanb
thanks! thats a big help
