20v mega squirt question....o2 sensor wiring
I have a fully wired msn2e to my silvertop 20v but I don't see any wires extended or possibly pre wired by the last owner for the o2 sensor on the header
Re: 20v mega squirt question....o2 sensor wiring
Maybe the P.O. was running the system in an open loop mode?
s24a wrote:Maybe the P.O. was running the system in an open loop mode?
Would be a good explanation why it runs fine without it. Will a standalone lc-1 kit be appropriate???
If you wish to ascertain if the previous owner did a good job (or had done by someone else), then yes, you can use an LC-1 to monitor and record the A/F at the exhaust to see if there are any overly rich or lean spots.
You could then use that information, along with recorded MAP, RPM and TPS to look at the Megasquirt tables to modify if found to be too rich or lean.
It can also help with cold start, altitude and acceleration tables as well.
s24a wrote:If you wish to ascertain if the previous owner did a good job (or had done by someone else), then yes, you can use an LC-1 to monitor and record the A/F at the exhaust to see if there are any overly rich or lean spots.
For sure thanks!
i think a wideband is definitely worth having especially on MS! closed loop is great!
Tuneshttps://truck.it/p/1Dl1ejMkZq
85' AW11 MS3/X Full Sequential w/ COP (DD)
87' AW11 Spare Shell
88' FJ62 MY BABY
91' AE92 DX Gutted, caged, @15psi GRMS challenger
91' AE92 DX Spare Shell
94' AE101 7AFE Backup DD
03' CBR 954 RR FireBlade
88' FJ62 MY BABY
