16V Valve Spring Upgrade?
overspool
Postby overspool » Mon Apr 29, 2013 5:34 pm
I'm going in to replace some valve seals and was wondering if it would be worthwhile to upgrade the springs and retainers while I'm in there (25 years could wear out them springs). Stock cams, stock motor. Thanks guys!
carbd7age
Re: 16V Valve Spring Upgrade?
Postby carbd7age » Mon Apr 29, 2013 6:09 pm
Stock springs is all you need. Upgrading to something fancy is needed when you go with crazy cams, otherwise just get stock ones. Measures them as per the FSM to see if they even need to be replaced.
Knockoff Crew member #0001
overspool
Postby overspool » Mon Apr 29, 2013 6:50 pm
Hokay. I'll measure em, hopefully they're not too haggard.
