Current set up;
82mm 11.1 pistons
Toda-R 264/272 9.0mm
Custom valve springs
0.5mm metal head gasket
the rest would almost be standard.
I plan to change to CP Pistons 82mm 12.1 CR. Would i get a big difference from the current 11.1 CR? And also what RON rating must i run with? Is the head gasket safe to run 12.1 CR?
Thank you for the advice.
20v Blacktop engine advice needed
- speedmaster
Visit my FB fan page at https://www.facebook.com/speedmasteracing
Re: 20v Blacktop engine advice needed
With that pistons and a 0.5 headgasket i guess you're getting close to the 13:1 mark. With a 0.8 TRD headgasket on a bone stock BT you'll already achieve 11,5:1! Don't know about the pistons hitting the valves with such a thin gasket. But other people over here will tell you soon
For octane i think you need racing fuel or at least 100RON.
- speedmaster
onnaj wrote:With that pistons and a 0.5 headgasket i guess you're getting close to the 13:1 mark. With a 0.8 TRD headgasket on a bone stock BT you'll already achieve 11,5:1! Don't know about the pistons hitting the valves with such a thin gasket. But other people over here will tell you soon
hi bro. do you mean the CP pistons?
- speedmaster
BTW, is it advisable to replace the intake cam pulley to the adjustable type? Im running Adaptronic and will only be used in 1/4 race.
gaijin_rokurunner
Wont do much increasing compression u need higher lift cams to work hand in hand with that also better valves to take advantage of the cams...hit me up i can help u setup your engine! PM me or email me nuffsaid02@aol.com
- speedmaster
tq bro
speedmaster wrote:onnaj wrote:With that pistons and a 0.5 headgasket i guess you're getting close to the 13:1 mark. With a 0.8 TRD headgasket on a bone stock BT you'll already achieve 11,5:1! Don't know about the pistons hitting the valves with such a thin gasket. But other people over here will tell you soon
Yes i mean in combination with that pistons yes!
