I have a fresh rebuilt 4AGE 20V BT. I runs okay, a bit of hestitation but that's most probably because of a worn TPS sensor. Maybe it's damaged during transportation from japan
We noticed we hear the valves a bit. The ticking noise is more present than with the 7AFE. I have to admit i don't have a radio and my glove compartement in, so i hear it better, but still it's a bit more then with the 7AFE. Does the 20V always make a bit more valve noise then other engines, regarding it has 20 valves instead of 16 in my old engine?
When cold the noise is less then when it warms up by the way. It seems to disappear above approx 3k rpm. Didn't go any higher then 3750 RPM or so, cause it's in the break in so i want to be carefull.
Thanks!
