Burning Oil On Rebuilt Engine
cmt1390
Postby cmt1390 » Mon May 20, 2013 10:22 pm
OK guys, Engine was fully rebuilt with EVERYTHING NEW and properly sealed no leaks, no smoke on low or high revs, nothing to give a hint you can just smell the oil inside the car after 15 minutes of engine running. I'll say again every seal and gasket was brand new when rebuilt and even the valves seals are new. I'm using 20w 50 grade oil mainly because I'm in the Caribbean and is always hot down here and secondly because the engine runs a lot for extended periods of time. But trying to figure out what is wrong? Any heads up? :? :? :?
cmt1390
Re: Burning Oil On Rebuilt Engine
Postby cmt1390 » Mon May 20, 2013 10:47 pm
A quart every two weeks.......... I'm thinking maybe one of the valve seals........
Postby totta crolla » Tue May 21, 2013 1:16 am
Is this a rebored engine with new oversized pistons ?
cmt1390
Postby cmt1390 » Tue May 21, 2013 7:25 am
no is got the Std. size pistons one the block only received a honing. And the thing is its only used 2-3 times a week. And you can just smell the oil cooking itself....... but it's not visible.
allencr
Postby allencr » Tue May 21, 2013 8:10 am
How much is 2 weeks??????????????????????????????????????????????????????
Also, it is never from valve stem seals!
Postby yoshimitsuspeed » Tue May 21, 2013 9:26 am
Did you rebuild it or did you get it done professionally?
How was it honed? How was it measured? Were the pistons and bores in spec?
Are you positive the oil rings were installed properly? It's is not too hard to mess them up.
Postby oldeskewltoy » Tue May 21, 2013 3:11 pm
yoshimitsuspeed wrote:Are you positive the oil rings were installed properly? It's is not too hard to mess them up.
if it isn't leaking... and it isn't being sucked down a valve stem.... it has to be the oil control rings
cmt1390
Postby cmt1390 » Wed May 22, 2013 6:20 pm
aprox. 10 engine hours every two weeks......the funny thing is that it started over month 1/2 ago at first it was fine
this picture was taken during the rebuild process...what do you guys think? they oem blacktop pistons and the rings were new...... is it possible the c/r could bust them? this engine is lil bit over 13 can't remember right know and yes it uses 100 octane gas and the engine runs a little rich :? :? :? :?
cmt1390
Postby cmt1390 » Wed May 22, 2013 6:25 pm
and if it was the rings I should be able to see the smoke???
8Ton
Postby 8Ton » Wed May 22, 2013 7:04 pm
was a torque/hone plate used when it was honed?
cmt1390
Postby cmt1390 » Thu May 23, 2013 5:59 am
8Ton wrote:was a torque/hone plate used when it was honed?
honestly I was not there that day so I can't confirm it. I'll just go ahead and buy new rings if that's the case...... The rings were installed properly that I'm sure. What went wrong I would like to know since I'm yet to know all their is about these engines. :|
allencr
Postby allencr » Thu May 23, 2013 6:39 pm
What's the compression?
Any of the plugs look oiled or all equal?
cmt1390 wrote:The rings were installed properly that I'm sure. What went wrong I would like to know since I'm yet to know all their is about these engines.
No secrets. There's zero difference, especially in this area, between it and any other internal combustion engine, diesels included, Wankels excluded.
Oil rings are difficult to F'up, so I'm guessing that a 2nd ring is broken or upside down.
Forget the hone plate stuff.
Good luck.
Garage7RP
Postby Garage7RP » Sun May 26, 2013 10:16 pm
I think the piston rings are not seated properly yet. Try using straight SAE 30 weight oil only for 3000 miles and it should do the trick. Do not use synthetic during this break-in period.
