4AGE 16V REDTOP Vacuum lines
Looking to get an engine bay pic of the vac lines and their connections for a FWD layout...mines is a total mess..help me out here fellas thks
Re: 4AGE 16V REDTOP Vacuum lines
check under your hood you should have a sticker that gives you the vacuum diagram.
The sticker has been removed....the engine on the car has been changed from bigport to a small port...and these engines aren't very common where am at ' The Caribbean' and since the engine went into the car the vac lines where never properly sorted. Am looking for pics,diagrams anything to help me out right now because it's my daily driver
Seriously NO one has any input on d vacuum lines connections for this engine?
I tried searching the interweb for you and couldn't find ****. I'm guessing it's very similar to the big port setup minus the tvis
If you end up finding one definitely post it up.
