Igniter issues
Mikare
Igniter issues
Postby Mikare » Sat Nov 30, 2013 7:27 pm
Got a "14" engine code. Already change the igniter yet it still won't start. Sometimes it would start and idles for a few minutes then dies. Symptoms before was hesitating while in constant throttle.
Aside from the igniter, any other sensors or equipment that may have contributed to this problem? fuel pump?
gotzoom?
Re: Igniter issues
Postby gotzoom? » Tue Dec 03, 2013 4:44 pm
See if you have a broken wire on the harness where it plugs into the distributor.
Re: Igniter issues
Postby jondee86 » Tue Dec 03, 2013 6:47 pm
This ^^^^.
Re: Igniter issues
Postby MisterJerk » Thu Dec 05, 2013 4:12 pm
make sure no oil in the dizzy. Check all connections from dizzy to coil.
apsogosGTi
Re: Igniter issues
Postby apsogosGTi » Thu Dec 12, 2013 10:06 am
for the history the only thing that has failed afte 20+ years is the igniter......have tried another one ?
