pls do inform me and lecture me about the mods i should do to my blacktop engine to gain maximum power and torque
i want to make the internal stok
so just want to maximise it
and i drove for city cruise
sometimes drag race also
i installed and tuned with MS1 v2.2 board
i plan to buy the velocity stacks but still need to be sure which lenght
also need to install the header
please anyone help me
thanks
need help 20v black for street mods
Re: need help 20v black for street mods
victorgarage wrote:pls do inform me and lecture me about the mods i should do to my blacktop engine to gain maximum power and torque
What does this mean?
No compression change?
No cams?
Not much you can do without changing internals.
Most people say some 100mm or 110mm stack will give the best improvement over the complete range.
Shorter will gain you power but loose torque.
Simpelst mods you can do are intake, header and exhaust.
onnaj wrote:Most people say some 100mm or 110mm stack will give the best improvement over the complete range.
Torque is irrelevant and comparing torque and hp is like comparing liters of water to liters per minute flow. It doesn't work.
yoshimitsuspeed wrote:onnaj wrote:Most people say some 100mm or 110mm stack will give the best improvement over the complete range.
The TS wants max torque and hp, so it's indeed important. Only thing is to know what he likes most. He said it's he'd like to cruise also so a bit of torque is important imo.
onnaj wrote:yoshimitsuspeed wrote:onnaj wrote:Most people say some 100mm or 110mm stack will give the best improvement over the complete range.
My point is that torque is a measurement of force applied. HP is a measurement of work done. Until you add RPM torque does not tell you how much work can be done. Once you have RPM you can measure potential energy IE HP, KW etc.
When people say they want more torque what they mean is they want more low end HP. People just don't know how to use proper terminology.
this is incorrect, if you fit shorter than 70mm you loose power everywhere. Quite often going longer gives you more power in the real world.
Wow this is refreshing to read. Well done for understanding the concepts.
Sam_Q wrote:Wow this is refreshing to read.
Wow, someone who appreciates it and doesn't want to argue about how wrong I am.
victorgarage wrote:i installed and tuned with MS1 v2.2 board
I would suggest upgrading to an MS2 or MS3. The MS2 has good tools for ITB tuning, and the MS3 has some AWESOME tools for VVT, ITBs, limp-mode, and other things which make daily driving much better.
I'd also suggest some cams. Honestly. They're not hard to install, and some mild cams really wake things up.
Pursuing the ideal
