4age 20v (BT) itb dimensions
Posted: Tue Feb 04, 2014 1:52 am
by onnaj
Hello,
Does anybody know the exact dimensions of the 20V ITB's? I thought the BT butterflies were 45 mm? What's the distance betweens the holes of the flanges, etc etc?
Thanks
Re: 4age 20v (BT) itb dimensions
Posted: Wed Feb 05, 2014 9:21 am
by burdickjp
onnaj wrote:Hello,
Thanks
which flange?
On the trumpet side:
Throttle opening is 50mm
Throttle openings are on a 87.5mm spacing
Hardware is M8
Hardware is on an 83mm spacing
Source:
https://drive.google.com/file/d/0B0RQCb ... sp=sharing
Posted: Mon Feb 10, 2014 6:01 am
by Sam_Q
If you want to be exact then the opening is about 49.5mm, everyone just uses 50mm I.D stacks though.
What do you have in mind?
Posted: Mon Feb 10, 2014 7:10 am
by onnaj
Thanks for all the info. It's not for me but someone else
Mine is sitting on the blacktop and won't move
Posted: Sun Mar 09, 2014 5:57 pm
by Stobe
Do you know what is the length of the intake manifold + ITB's (i mean the length of the whole assembly without the stacks)?
Posted: Sun Mar 09, 2014 6:19 pm
by burdickjp
Stobe wrote:Do you know what is the length of the intake manifold + ITB's (i mean the length of the whole assembly without the stacks)?
This is what I had written down. Not sure if it was my measurements or copied from someone else:
Center intake valve to intake face: 115mm
Peripheral valve to intake face: 120mm
intake face to throttle face (gasket, manifold, throttle): 183.5mm
Posted: Mon Mar 10, 2014 12:54 am
by Stobe
Thank you!
Posted: Wed Mar 12, 2014 2:07 am
by Stobe
Oh, another question (sorry for hijacking the topic/off-topic). Has anyone measured the width of 20V cylinder head (and 16V head)? Which on is wider. I am just asking that because i have KP61 and i have only a block this far, and i am tring to measure how "deep" airbox i can use, before it hits the strut tower.
Posted: Wed Mar 12, 2014 7:02 am
by Stobe
I will start a new thread, so it is easier to find for someone looking the same info.
Posted: Fri Apr 04, 2014 8:20 am
by onnaj
Do you happen to have the dimensions/sizes at the engine side?
