Parts are located in the Netherlands and prices are excluding postage.
Prices are in euro's and based on the european market. If you're interested in a part but you think the price is not correct let me know and I'm sure we can work something out that is fair for the both of us.
See below for the parts list.
01. 2S Bellhousing including clutch fork and release bearing with carrier. Can be used to mate 3sge engine to W5* gearbox - €300
02. MR2 4AGZE wiring loom with relay boxes etc... - €50
03. 4AGZE Coils and leads (19080-16020) - €125
04. 4AGZE aircon bracket (12511-16060) - €35
05. 4AGZE alternator bracket (12511-16080) - €35
06. 4AGZE bracket, don't know from what - €15
07. 4AGZE bracket, don't know from what - €15
08. 4AGZE supercharger bracket (17625-16010) - €25
09. 13" spare wheel, good condition 185/70/13 tire with 6-7mm thread left - SOLD
10. Spare wheel cover - SOLD
11. AE86/KE70 gearbox mount (12371-34030) - €25
12. OEM AE86 Aircon condensator/radiator - €25
13. OEM battery brackets - €5 each
14. Seatbelt buckle - €5
15. Blue buckle strap - €10
16. Pair of brown/red buckle straps - €20
17. Pair of gray buckle straps - €20
18. TOYOTA center piece between rear lights (hatchback), crack on backside at mounting studs but repairable with some glue - €50
19. Cover bellhousing - €15
20. Clutch slave cylinder (new) - €25
21. Custom catch can from brushed aluminium. With internal baffles, level indicator and easy drain plug. For mounting on front of engine. - €100
22. Aft part of driveshaft AE86 - €35
23. Ducktail TRD copy for hatchback - €250
24. Flywheel AE86 200mm - €25
25. Gearbox mount - €35
26. Gearknob - SOLD
27. OEM Gearstick surround - €25
28. Horn cover - SOLD
29. OEM Indicator assembly - €150
30. 4AGE inlet manifold gasket - €5
31. Misc interior bits (doorhandles, windowhandles etc..) - Ask for price
32. Interior door part, brown-red - €15
33. JDM AE86 washer bottle €75
34. Kickpanel footwells driver and passenger side, brown-red - €20 each
35. Kouki indicators 2x R (one cover damaged), 1x L (cover missing) - Ask for price
36. Master brakecylinder AE86, needs to be revised - €25
37. Mudflaps, one rear - front ones sold, only one rear left - €35
38. OEM AE86 vent control valve (85430-12070) - €10
39. OEM AE86 vacuum valve (084600-5500) - €10
40. OEM AE86 vacuum valve assembly (89570-12220) - €25
41. OEM AE86 Left and right LCA - €125 for the pair
42. OEM AE86 panhard rod, bushes need to be replaced - €25
43. OEM AE86 radio (86100-12660) - €25
44. Oil dipstick - €10
45. 4AGZE Oil filter mounting block - €25
46. Pedal (78124-10050) - €15
47. OEM AE86 rearview mirror - €100
48. OEM AE86 seatbelt assembly, black - €125
49. 4AG(Z)E sensor - €15
50. OEM AE86 speedo cable new (83710-12310) - SOLD
51. Stainless steel coolant bottle - €50
52. OEM AE86 strut tops - €35
53. Supra gearbox mount (12371-42020) - €25
54. T50 gearbox speedo drive (22-6 ratio) - SOLD
55. OEM AE86 tankdoor - SOLD
56. OEM AE86 tank sender - €45
57. OEM AE86 dash unit, small crack in plastic front - SOLD
58. 4AGE timing gear backing plate - €20
59. Cover underside hatchback bootlid - €10
60. Vacuum control AE9* & AE10* (25740-16020) - €10
61. Vacuum switch (084600-3540) - €10
62. W5* gearbox speedo drive - €50
63. OEM AE86 washer bottle - €50
64. OEM AE86 Rear window wiper switch 2x - €15 each
65. OEM AE86 wheel arch trim complete set - SOLD
66. OEM AE86 Windowvisors, dirty condition - €15
67. Zenki indicators (3x R, 1x L) and lenses - ask for price
68. Complete automatic aircon set-up (incl control panel, pump etc..) - €100
PICTURES:
01.
02.
03.
04.
Sold
05.
06.
Sold
07.
Sold
08.
09.
SOLD
10.
SOLD
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Sold
21.
22.
Sold
23.
24.
25.
26.
SOLD
27.
28.
SOLD
29.
Sold
30.
31.
32.
33.
34.
35.
36.
37.
Sold
38.
39.
40.
41.
42.
43.
Sold
44.
Sold
45.
Sold
46.
47.
48.
49.
50.
SOLD
51.
52.
53.
54.
SOLD
55.
SOLD
56.
57.
SOLD
58.
59.
60.
61.
62.
Sold
63.
Sold
64.
65.
SOLD
66.
Sold
67.
68.
Pictures upon request
