Up for sale a rare 1987 kouki diff, it has one bent axle shaft on the driver side so its good for parts or pull it out and replace it, it also needs the dust shield on that side too (rotten off). Diff and other axle shaft are good but the housing needs a good cleaning for paint or you can leave it as is.
The rods and flex lines are good except the lateral control rod (long one) needs bushings on both ends.
220,000Km (137,000 miles) on the diff
SOLDPick up only in toronto, ontario
