its that time again, here's my list of stuff not needed.
I ONLY HAVE WHAT YOU SEE, these are all of my parts for sale
I DO NOT WANT TO DEAL WITH INTERNATIONAL SHIPPING, please dont ask, sorry.
Parts located in North East NJ, willing to meet up, have you stop by, or ship.
Prices as listed, do not include shipping/paypal fees, unless noted.
If its "FREE" then thats what it is for the part. please dont be greedy and ask for a bunch off free stuff and nothing else.
Parts1
1. SOLD
2. SOLD
3. SOLD
4. 4age 20v motor/trans brace-free
5. SOLD
6. SOLD
7. used ae86 front brake lines-free
8. SOLD
9. SOLD
10. ae86 brake master cylinder res. w/cap-free
*not #’ed-ae86 antenna bracket-free
11. SOLD
12. fwd 4age rear head outlet-$5
13. door latch/loops-$5
14. ae86 rear drivers sidewheel well guard(3 pieces)-$2.50/each
15. fwd 4age rear head outlet-$5
Parts2
16. door opener cups/pair(painted satin black)-$5
17-20. misc. door opener cups-$2.50/pair
21. ae86 seat belt retractor bezel/pair(painted black)-$2.50
22. ae86 seat belt retractor bezel(oem bluish grey)-free
23. SOLD
24. SOLD
25. single window crank(oem black)-$5
26. SOLD
27. ae86 oil pressure sensor(reads about one bar lower than it really is on gauge)-$5
28. fwd(aw11 mr2?) oil pressure sensor-$2.50
29. 4age 20v oil pressure sensor(2 pieces)-$2.50/each
30. ae86 4age temp sensor for cluster-$5
31. SOLD
32. SOLD
33. SOLD
34. 4age 20v ECU water temp sensor-$5 (1 w/pigtail=SOLD)
35. wheel caps(62mm diameter hole)-$15/set of 4 bnib
36. SOLD
37. SOLD
38. SOLD
39. ae86 bluish grey rear seat buttons-$2.50/set
40. ae86 hatch rear blue hook-free
41. 4age 20v valve cover ventilation valve-$10
42. large pocket cover on cluster surround(painted white)-free
43. ae86 gauge cluster surround lights(above light & wiper switches)-$2.50/set
44. ae86 fuel door lock/popper-$10
45. fwd 4age crank pulley bolt-free
46. ae92 sun visor mount-free
47. 4runner/ae86 sunvisor mount(needed to use ae92 visors in ae86)-$5/set
48. SOLD
49. SOLD
50. “Toyota” emblem-$5
51. SOLD
52. SOLD
53. SOLD
Parts 3
54. ae86 sr5 starter(2 pieces)-$20/each
55. ae86 clutch slave(no push rod)-$5
56. ae86 front wheel bearing grease caps-$2.50/set
57. SOLD
58. SOLD
59. SOLD
60. ae86 hatch “C” pillar(Drivers side-no rust)-$15
61. ae86 hatch “C” pillar(Passengers side-no rust)-$15
62. ae86 rear bump stop set-$10
63. SOLD
64. ae86 sr5 evap purge tank and solenoid-$5
65. SOLD
Parts4
66. SOLD
67. ae86 sr5 front sway bar-free
68. SOLD
69. ae86 hood latch/release with support-$15
70. 4age 20v injector wire cover-$5
71. fwd 4age(aw11 mr2) throttle body-$5
72. ae86 side moulding end pieces(fenders-thick mouldings)-$5/set
73. ae86 driveshaft center bearing shield-$5
74. ae86 hood hinges-$10
75. SOLD
76. SOLD
77. exhaust flange(303 s.s. w/3” opening)-$5
78. SOLD
79. ae86 front ashtray(burgundy)-free
80. SOLD
81. AE72 hatchback door opener bezel(1983)-$5
82. 1 ae86 passengers side door hinge(no wobble-need to confirm top or bottom)-$5
83. modded coolant line for 20v(ae86 heater core to ae86 rear housing pump-$5
84. SOLD
85. SOLD
86. ae86 hatch lid lock-$10
87. SOLD
88. SOLD
89. AE72 hatchback rear washer fluid bottle-clean/no cracks(1983)-$15
90. SOLD
Parts5
91. ae86 hatch wiper motor-$15
92. ae86 a/c electrical idle up valve-$10
93. 4age fwd aw11 mr2 ERG valve-$5
94. media blasted ae86 drivers side motor to trans bracket-$5/dirty bracket=SOLD
95. SOLD
96. fwd 20v lower alternator bracket-free
97. fwd 4age water pump pulley-$5
98. SOLD
99. ae86 hatch rear window washer pump-$2.50
100. SOLD
101. ae86 windshield cowl vent-$2.50
102. SOLD
103. SOLD
104. SOLD
Part7
105. ae86 lower door sill gasket(3 pieces)-$2.50 each
106. SOLD
107. SOLD
Parts8
108. ae86 lower door trim piece(set-1 piece was bent)-free
109. ae86 lower door trim piece(set-some overspray on them)-free
110. ae86 coupe drivers rear window trim(missing lower piece)-$5
Parts9
111. ae86 interior vertical door trim at rear panels(painted black)-$5/set
112. ae86 interior vertical door trim at rear panels(oem black)-$10/set
113. SOLD
114. SOLD
115. ae86 passengers kick panel(faded oem blue)-$5
116. ae86 interior pass. side door/carpet trim(oem blue)-$5 *drivers side SOLD*
117. ae86 coupe rear headliner trim(oem black)-$10
118. SOLD
Parts10
119. ae86 interior “B” pillar trim-drivers side(painted black)-$5
120. ae86 interior “B” pillar trim-drivers side(oem black)-$10
121. Levoc shift knob-$5
122. ae86 seat belt sheath(oem black)-$2.50
123. ae86 drivers side female seat belt connector(oem black)-$5
124. SOLD
125. SOLD
126. SOLD
127. ae86 bnib oem black clock bezels(2 pieces)-$20/each shipped
Parts11
128. ae86 power mirror harness-$5
129. ae86 window track w/rubber(think its drivers front)-free
130. ae86 window track w/rubber(think its passengers rear)-free
131. ae86 window track-2 pieces w/rubber(think theyre drivers rear)-free
132. SOLD
133. SOLD
134. ae86 door stop/brace-free
135. ae86 outer door trim-free
136. SOLD
137. SOLD
138. SOLD
139. ae86 hatch rear interior panel brace/set-$5
140. ae86 drivers window regulator(no play in crank shaft)-$40
141. ae86 outer door trim-free
142. SOLD
ae101 steering wheel-$60 shipped
^back up after buyer couldnt figure out how to mount a steering wheel and complained it didnt fit. pictures prove otherwise...
ae86 exhaust heat shield set-$15
mk3 supra intermediate shaft-SOLD
ae86 hatch rear windows-$20/side
T3 ITB splash guard=SOLD
my repro ae86 battery tie-downs-$40 shipped/each
***comes with what you see in 1st pic: tie-down, J-hook(oem from dealer), washer & nut for hook***
FITS OEM SIZED BATTERY ONLY
no time to make these anymore, these are the last 5 for a while. lifes too busy...
***SOLD OUT***
ae86 doors complete with what you see(no hinges or regulators-glass is included however). started body work on passengers side-$100/set obo
drivers has little crease near outer handle and chip in mirror housing
if you dont like what you see, please move on and keep negative comments to yourself.
thanks for looking.
