MKII SUPRA REAR END AXLES. Good condition but the axle with the gear at the end slid right out of the pumpkin which it shouldn't do. So I don't know what's up with that but shouldn't be a big deal to fix. One axle's Boot slipped out of it's groove. Just replace the worn out clamp with a new worm drive clamp. Should be fine then.
Also, selling the LSD in pumpkin. I have no idea if it works. I never tested this one. I had an LSD in better condition.
I also have another LSD in pumpkin. That one is shot but u can have it to rebuild or whatever.
And I also have an OEM GTS Sway Bar.
This add is mainly for the axles. If you only want the axles they are $40. But you can take as much of the other items as you want for $50
call/text Michael (760)672-9740
MKII SUPRA REAR END AXLES + LSD AND MORE!
LeafOnTheWind
- grappletech
Re: MKII SUPRA REAR END AXLES + LSD AND MORE!
87 SR5 Coupe Shell. (Sold)
86 SR5 Hatch Shell
86 GT-SR5 Coupe 20v Swap
86 SR5 Hatch Shell
