PRESTINE Digi Cluster!
ritz
Postby ritz » Tue Sep 09, 2014 12:00 pm
$300 shipped! Comes with new RED LEDs installed :D
Esenpai
Re: PRESTINE Digi Cluster!
Postby Esenpai » Tue Sep 09, 2014 12:15 pm
looks almost as shiny as mine! spent some good time polishing that thing up. i went with the red too. glws
ritz
Postby ritz » Fri Sep 12, 2014 10:53 am
ttt
Gettin-little
Postby Gettin-little » Wed Sep 17, 2014 6:38 pm
does this also come with the fuel/oil sending unit? and what other items would b need to make this work in a usdm 85'gts/levin?
ritz
Postby ritz » Wed Sep 17, 2014 9:14 pm
Gettin-little wrote:does this also come with the fuel/oil sending unit? and what other items would b need to make this work in a usdm 85'gts/levin?
fuel sending unit is $100 or so from EP Importers or if you can source one from a cressida with digital cluster.
The digital senders have a blue cover on top which makes it distinct from the normal black ones.
The oil sender is $10 from your local parts house. They're from 90s MR2, Camrys, Celicas.. or basically any other Toyota with a low oil warning light, and not a mechanical gauge.
You will also need to find or make your own conversion harness.
It's not uncommon to see a complete set for $600. This is just half the puzzle.
As a matter of fact, I will include the oil pressure sensor with your purchase :)
