AE86, S13, S14 Parts for sale!
Posted: Mon May 05, 2014 4:55 pm
Sorry I don't post here as I don't usually have AE86 parts. Check Zilvia for references. Probably best to text (415-724-0675)as I don't think I'll check here often.
I am looking for a S13 welded diff in pumpkin (Norcal local only) Trade?!
Located in Petaluma CA.
Updated the list 5-5-14
(415) 724-0675
AE86 COROLLA PARTS
Whole 20v swap or parting
- 20v Toyota Corolla Swap - Entire running drivetrain and radiator, many extras - $2500
20v head and block - $700
T50 Trans w/ GTS bellhousing - $300
New ACT 4 puck clutch kit - $200
Lightweight flywheel - $180
T3 first gen shifter - $140
Mishimoto Aluminum Radiator - $150
First Gen TRD Header - $200
Straight Pipe AE86 Exhaust - $180
Megasquirt ECU and ALL electronics and sensors - $400
240SX ENGINE PARTS
SR Red Top Thermostat Housing - $10
SR20 Flywheel Bolts - $20
S13 KA24DE Fan - $20
S13 KA24DE Air Box - $20
Megan Racing SR exhaust manifold - $70
SR20 Redtop IACV - $75
Power FC L-Jerto (maf version) - $700
ACT 6 puck sprung hub clutch/heavy pressure plate (new clutch disk) - $400
Megan Racing Short Shifter - $70
SR20 Alternator - $65
SR20 O2 Sensor - $35
SR20 Coil Packs - $100
SR20 Redtop Valve Cover, powder coated white - $75
SR20 Circuit Sports Rocker Arm Stoppers - $35
SR20 Cam Angle Sensor - $100
SR20 Coil Pack Harness - $75
DRIVETRAIN
S13 Rear Subframe - $80
S13 5 speed non abs drive shaft - $70
S13 4 Lug Hubs (rear only) - $35 per pair
NEW S13/14 Rear Axle hardware kit - $30 (pair)
SUSPENSION
Pairs of 5x114.3 10mm slip on spacers - $25
S13 Driver Side Tension Rod Bracket (have 2) - $30
S14 Stock knuckles - $50
I have all S13 and S14 stock suspension so let me know what you need
BRAKES
2 Brembo Blank Z32 rear rotors (good condition) - $40
Carbotech race Z32 rear brake pads - $30
SS Z32 Rear Conversion Lines - $35
INTERIOR
S13 Cluster Surround - $35
S13 Steering Wheel Adapter (nardi pattern) - $20
S13 Rear View Mirror - $15
S13 Center Console - $30
S13 Clean Dash - $150
S14 Glove Box, grey or black - $40
S14 Confetti rear seats - $50
S14 Cluster Surround - $35
S14 Grey Carpet - $40
S14 Center Console - $50
S14 Interior Mirror - $20
S14 Steering Column Switches (blinkers, windshield wipers etc.) - $35
S14 Steering Column Trim - $20
Center shift boot with metal ring (universal) - $40
EXTERIOR
S13 Hatch Rear Bumper (primer) $35
S13 Fastback Center Tail Light - $35
S13 Fastback Passenger Side Tail Light - $30
S13 Doors - $40 each
S14 Kouki Front 30mm Overfenders - $150
S14 doors - $60 each
S14 Zenki tail light center panel - $35
S14 Zenki Driver Side Tail Light - $30
S14 Roof (good for welding in to replace sunroof panel) - $100
S14 Quarter Panels - $75 each
MISC
S13 Hood latch with cable - $25
S13 Upper Radiator mounting brackets - $15
S13 Windshield wiper motor - $10
S13 Gas Tank Door - $15
S13 Gas Tank (local only) - $40
S13 WORKING hatch struts - $30
S13 Steering column - $40
S14 Radiator Overflow Reservoir - $35
S14 Gas Tank (local only) - $100
S14 Steering Column - $40
(415) 724-0675
I have EVERYTHING so if you don't see it post/pm me. All stock parts are available. Shipping is also available on most parts.
