Garage clean out interior suspension misc
marin86
Postby marin86 » Wed Jul 22, 2015 4:05 pm
I have a bit of stuff that's piling up and need to make room. Everything is best offer and trades are welcome. My prices are all based on prices I found on the Internet. I have no problem shipping any item but it is not included in the prices. Located hour north of San Francisco.
1. levin front bumper - $220
2. speaker cover panel drivers side - $20SOLD
3. speaker cover panel drivers side - $25SOLD
4. under cluster/ steering trim piece - $30SOLD
5. under cluster/ steering trim piece - $35SOlD
6. driver side heater venting - $10
7. trueno grille - $350
8. stereo - $20
9. center trim plastic - $10SOLD
10. shift trim cracked -$10
11. ebrake trim with ashtray - $30
12. passenger side dash speaker trim - $20SOLD
13. passenger side dash plastic - $10
14. driverside lower kick panel - $10SOLD
15. passenger side floor heater venting - $10
16. driverside a-pillar panel - $15
17. passenger seat belt upper b-pillar panel - $10
18. rear hatch speaker passenger side $30SOLD
19. passenger side dash speaker trim - $20SOLD
20. right rear lower hatch trim panel - $10SOLD
21. left rear lower hatch trim panel - $10SOLD
22. hatch lower left/jack cover panel - $25SOLD
23. driver side upper seatbelt trim b-pillar -$15
24. driver side hatch speaker trim - $30SOLD
25. passenger side rear lower hatch panel - $10
26. driver side rear lower hatch panel - $10
27. lower b-pilar trim passenger side - $7
28. lower b-pillar trim driver side - $7
29. passenger side kick panel - $10
30. ashtray - $6
31. passenger uper a-pillar to b-pillar panel - $15SOLD
32. passenger b-pillar to c-pillar panel $15SOLD
33. passenger hatch lower panel - $20SOLD
34. hatch lower center plastic - $15SOLD
35. driver side hatch lower panel - $20SOLD
36. hatch lower center panel - $20SOLD
37. hatch lower passenger panel - $15SOLD
38. hatch lower driver side panel - $15SOLD
39. driver side rear seat side panels - $35SOLD
40. passenger side rear seat side panels - $35SOLD
41. rear hatch cover pioneer 6x9 speaker $70
42. glove box - $50
43. shifter center console panel - $20
44.ebrake center console panel - $28
45. rear ashtray center console - $2
46. passenger b-pillar pnel - $10
47. passenger hatch corner panel inset - $10SOLD
48. passenger hatch corner panel inset - $5SOLD
49. lower 1/2 steering column trim - $20
50. Jack cover - SOLD
51. misc seat trim
52.misc seat trim
53. misc seat trim
54. maroon rear seat trim for carpet - $5
55. maroon rear seat trim for carpet - $5
56. hatch lower right panel - $10SOLD
57. hatch lower left panel - $10SOLD
58. hatch lower driver side corner panel - $10SOLD
59. hatch lower driver side corner panel - $7SOLD
60 jack cover - SOLD
61. hatch speaker trim - $17
62. wheeel well rear cover - $5
63. wheeel well rear cover - $5
64. center console bracket - $5
65. rotten mirror - $1
66. heater venting - $3
67. handle? - $5
68. rear strut trim cap - $3
69. rear strut trim cap - $3
70. misc - $1
71. misc - $1
72. seat adjust knob
73. battery hold down - $20SOLD
74. roof hook - $3
75. seat belt trim cap - $2
76. rear seat latch - $10
77. rear seat latch - $11
78. trim piece - $1
79. seat adjust knob
80. seat release lever
81. rear floor mat - $5SOLD
82. rear floor mat - $5SOLD
83. rear upper seats with carpet - $25SOLD
84. rear lower seats - $21
85. FWD 4age water pump BNIB - $65
86. shifter boot - SOLD
87. heater water valve - $20
88. heater water valve - $20
89. TE-27? transmission crossmember - $30
90.manual rack bracket - $20
91. manual rack bracket - $20
92. manual rack bracket - $20
93. sway bracket? - $5
94. bracket - $5
95. bracket - $5
96. bracket - $5
97. power rack bracket - SOLD
98. power rack bracket - SOLD
99. window handle - $5SOLD
100. window washer reservoir with pump - $40
101. steering wheel - $20
102. spare wheel lock - $2
103. horn - $5
104. strut nuts $10
105. brake lines - $5
106. power steering intermediate shaft $15
107. front dust shield - $20SOLD
108. front dust shield - $20SOLD
109. AC condensor - $30
110. passenger fender liner - $35
111. drivers fender liner - $35
112. front strut casings - $150SOLD
113. front driverside caliper - $40SOLD
114. front wheel hub - $85SOLD
115. front dust boots - $20
116. front wheel hub - $85SOLD
117. front passenger caliper - $40SOLD
118. rear hts shocks - $300
119. drivers power mirror - $68
120. left kouki front bumper light - $30SOLD
121. right kouki front bumper light - $30SOLD
122. t-50 shifter - $40
123. top spring hat - $10SOLD
124. ecu - $50SOLD
125. tetas center caps $30SOLD
126. buzz box? - $3
127. relay window - $10
128. passenger clear kouki bumper corner light - $35SOLD
129. passenger clear kouki bumper corner light - $35SOLD
130. seat trim - $5
131. horn - $7
132. volanti horn button - $30
133. gas door release cable - $50
134. levin mud flaps - $175
135. jack and tools - $40
136. kouki rear bumper brackets - $180SOLD
137. resistor - $20
138. AE92 cluster button -
139. AE92 supercharger cluster and signal switches - $65
140. AE92 switch -
141. celica front seats - $30
142. kouki grille 53100-2232 -$340
143. sr5 axle - $35SOLD
144. sr5 axle - $35SOLD
145. exhaust test pipe - $40SOLD
146. door trim - $5
147. drivers fender trim - $5SOLD
148. passenger door trim - $5SOLD
149. front lower control arm - $60
150. front lower control arm - $60
151. antenna - $10sold
152. antenna mounting cables - $6sold
153. shift knob - $5
154. BLAZE shift knob - $45
155. hatch cover - $30
156. fog lamps - $20
156. power steering knuckles and outer tie rods - $100
157. inner power steering tie rods - $25
158. 58.6mm strut spacer? - $5SOLD
159. hts front shocks - $300
160. strut casings with hubs - $320SOLD
161. front bump stops - $7
162. 6 kg trd front springs - $200
163. front top hats -$7
164. cusco camber paltes - $ 225
165. front carpet -$20SOLD
166. rear carpet - $20
NEW ITEMS
Front fc brake adapters $225SOLD
Front fc bake calipers $300SOLD
Front Mini Cooper drilled and slotted rotors $125SOLD
Brake hard lines $160
Fuel lines $160
Gts gas tank $200
1987 gts dash harness $250
Headlight harness $200
Rear harness $150
Cluster $200
Ecu $70
Doors $125 each
Shell $1000
Quarter glass $50 each
Ebrake cables $70
Gas/clutch/brake pedals $75
Ebrake handle $35
Ac/heater controls $70
Brake booster and master cylinder $55
Head lights /housings $150
Fender liners $70
Gts Drive shaft $175
Power mirrors $180
4link $50
TRD Kouki lsd with ring and pinion needs new bearings $575
AGX front and rear shocks $440 less than 5 miles
T3 black top hats $190
T3 Coilover conversion $220
sapito313
Re: Garage clean out interior suspension misc
Postby sapito313 » Wed Jul 22, 2015 8:33 pm
can you please post an email where I can send you a message for parts? Thank you
D_Hunt33
Postby D_Hunt33 » Thu Jul 23, 2015 11:18 am
how much for the Levin mud guards?
marin86
Postby marin86 » Fri Jul 24, 2015 11:22 am
sapito313 wrote:can you please post an email where I can send you a message for parts? Thank you
It's in my profile but azerathis@yahoo.com
marin86
Postby marin86 » Fri Jul 24, 2015 11:24 am
D_Hunt33 wrote:how much for the Levin mud guards?
I can't find any recent for sale on google search to reference price so shoot me an offer
marin86
Postby marin86 » Fri Jul 24, 2015 11:26 am
Hope I've replied to all texts, emails and pms but if I haven't it's not intentional just hit me up again and I'll get back to you
supertrooper85
Postby supertrooper85 » Sat Jul 25, 2015 4:03 am
Need the shifter bud. Where those steering rack brackets I saw?
marin86
Postby marin86 » Sat Jul 25, 2015 7:49 am
What's a shifts bud? And yes it's a mix of steering brackets?
chrisrodriguez822
Postby chrisrodriguez822 » Sat Jul 25, 2015 11:05 am
How much for the front strut assembly?
marin86
Postby marin86 » Sat Jul 25, 2015 11:19 am
$150
morgan
Postby morgan » Sat Jul 25, 2015 7:42 pm
Pic4, top right corner, orange corners price please
My turd of an 86
20v swapped 86 write-up
marin86
Postby marin86 » Sat Jul 25, 2015 8:20 pm
I just realized if you're looking at this in web browser and not tapatalk you're missing 1/3 of the right side of each picture. I don't know how to fix it? The orange lights are right and left inner kouki bumper lights. $30 each
Calikid
Postby Calikid » Sat Jul 25, 2015 10:41 pm
How much for the rear red shocks shipped to 29118?
calihachi86
Postby calihachi86 » Sun Jul 26, 2015 6:11 am
How much for the bumper brackets shipped to 91706.
marin86
Postby marin86 » Sun Jul 26, 2015 1:41 pm
calihachi86 wrote:How much for the bumper brackets shipped to 91706.
Did you also email me?
marin86
Postby marin86 » Sun Jul 26, 2015 1:43 pm
Calikid wrote:How much for the rear red shocks shipped to 29118?
$300 shipped also have front but need to find them
morgan
Postby morgan » Sun Jul 26, 2015 8:40 pm
marin86 wrote:I just realized if you're looking at this in web browser and not tapatalk you're missing 1/3 of the right side of each picture. I don't know how to fix it? The orange lights are right and left inner kouki bumper lights. $30 each
Crap thought they were zenki. I just saved the pics to my phone and i can see it all. I usually get the forum code, and have the pic in a smaller size, idk if you can do that.
Pic5, is that an oem black unpainter jack cover, lower left area?
My turd of an 86
Calikid
Postby Calikid » Sun Jul 26, 2015 9:14 pm
300 for all four? lmk when you find the fronts and send pics if you can thanks.
D_Hunt33
Postby D_Hunt33 » Sun Jul 26, 2015 9:25 pm
Will you do $30 for the Levin mud guards? not really sure what they go for i just think they would look cool on my car haha
marin86
Postby marin86 » Sun Jul 26, 2015 9:28 pm
$550 shipped for four and $300 for two
marin86
Postby marin86 » Sun Jul 26, 2015 9:30 pm
its mostly red and maroon interior. Pic 5 not sure which piece you're looking at.
marin86
Postby marin86 » Sun Jul 26, 2015 9:32 pm
D_Hunt33 wrote:Will you do $30 for the Levin mud guards? not really sure what they go for i just think they would look cool on my car haha
theres a set going for $220 on eBay so $30 is little lower than I had in mind
D_Hunt33
Postby D_Hunt33 » Sun Jul 26, 2015 10:09 pm
Wow didn't realize they were so much, thanks for the time though, i appreciate it.
calihachi86
Postby calihachi86 » Mon Jul 27, 2015 1:54 am
yeah. emailed you again.
goofesgts
Postby goofesgts » Mon Jul 27, 2015 10:31 pm
How much for the two toyota center caps shipped to connecticut ?
how can i go to heaven? accepting jesus christ as youre savior!! thats youre ticket to heaven!
eightsixgts
Postby eightsixgts » Mon Jul 27, 2015 10:43 pm
How much for both the rear speaker/parcel trays in picture 5... thanks!
bboys34
Postby bboys34 » Tue Jul 28, 2015 8:17 am
Hello how much for that driver side mirror shipped to 90650? Thanks.
marin86
Postby marin86 » Tue Jul 28, 2015 7:40 pm
Pmed responses
marin86
Postby marin86 » Fri Jul 31, 2015 3:29 pm
Pms sent. Parts updated
Toejam86
Postby Toejam86 » Sat Aug 01, 2015 11:47 pm
is the hatch cover still for sale?
and are you willing to ship to miami?
