HUGE ae86 race car project part out- all BNIB parts, LA area
illwillem
Postby illwillem » Fri Jul 31, 2015 7:07 pm
Massive part out of my project. Pretty bummed about the whole situation and after going back and fourth on the whole thing a couple times I just need to pull the trigger and move on.
ALL THE PARTS ARE NEW The only difference between 'new' and 'BNIB' are the 'new' items didn't come in a box (ie swaybars, door cards etc). If something doesn't say 'new' or 'BNIB' its can probably still be considered 'new' as nothing I bought for the car has ever been used.
Link to the build blog here- pictures galore of all the parts with explanations http://illvillains.blogspot.com/2014/06/parts-parts-and-more-parts.html read forward along too see pictures of everything listed here.
Prices are FIRM unless you're buying multiple things- if so, we can discuss multiple item deals. Like I said, this is all unused stuff so basing the prices off a master receipt list Ive kept. I'm eating tax and shipping fees plus the 15-20% i took off too reach the prices I listed here. Its what im comfortable walking away from, I'm not giving **** away so don't be a dick. Cool? Cool.
you can PM here or text too (8 oh f1ve) 5 f1ve 8ight - 0ne tw0 oh tw0.
Most of the stuff is located in Baldwin Park CA but i live in Burbank/LA
Ill update as things sell- if its listed I still have it.
4 Corolla coupe t3 rear cards, new $90
6 Sparco Corsa seat, red, used $240
8 IZZe engineering air pump jumper chip, s2000, BNIB - $55
9 Herse main battery cut off switch, new - $20
12 s2000 ECU, removed immobilizer $200
17 s13 rear rotors AX31063, BNIB - $40
20 AE86 f20c single piece drive shaft - $300
24 SPAL 13" puller fan 30102044, BNIB - $140
25 SPAL wiring harness kit 185* trigger SPU-IX-185FH, BNIB - $56
28 Mishimoto overflow tank MMRT-CA BNIB, fittings-hose incl - $66
31 AJPS s13 rear rotor upgrade kit for AE86, new - $190
33 Porterfield Brake pads (rx-7) AP331, BNIB - $65
34 JBT brake calipers w/titanium cups CRX/CIVIC - $220
35 15x8.5/8 -5 0 4x114 VOLK TE37V wheels - $1950
37 Hurst shifter cover - $10
41 AE86 coupe Lexan side windows, new protective film still on - $80
42 AE86 T3 triangle fender braces, new - $180
44 AE86 Porterfield front brakepads AP282 R45 (GTS caliper) BNIB - $60
45 AE86 Porterfield rear brakepads AP305 R45 (GTS rear caliper) BNIB - $40
46 AE86 Tanabe front swaybar with bushings, New - $255
48 AE86 T3 Lower control arms, new - $350
52 FAL electric fan 13' used-ish -$85
53 AE86 coupe rear Lexan window, new - $80
54 AE86 rear end 3rd member, assembled- JDM KAZZ 1.5 LSD, weir SC/turbo axle and side gear kit and new bearings, ARP wheels studs, Cusco panhard lowering plate welded on,
0 miles- never filled w/fluid comes with new can of Kaaz 80w-90 hypoid break in oil. Assembled by K1- ready to bolt in a go - $2700
56 AE86 T3 equal length 4-links, minus boxes, new. - $350
57 4x 17x8 +35 GOLD Regamaster MP w/80% RS3 - $2000
58 Precedo Demon Camber wheels 15x7/7.5 0/-5 4x100/114 perfect cond. - $1050
61 AE86 F20c modified crossmember tig welded plate reenforced, no joke- $330
63 RPF1 15x7 +26, gold, used once 4x100 - $650
64 OEM kouki axles L/R - $200 each
66 2x Walbro 255 fuel pump(s) - $95 each
68 Ae86 Coupe Kouki tail lights L and R - $240
Chassis in the blog is also for sale, its riveted, stitch welded, media blasted has a full fuel cell cradle built with aero provisions. Sun roof and fuel filler delete. Will come with a TON of other stuff. Its going with clean CA title for $3000.
mr2racer43
Re: HUGE ae86 race car project part out- all BNIB parts, LA
Postby mr2racer43 » Fri Jul 31, 2015 7:58 pm
What about the F20c and trans?? Thanks
kataomoi
Postby kataomoi » Fri Jul 31, 2015 10:59 pm
I sent a pm about the oem lsd.
Thanks.
marin86
Postby marin86 » Fri Jul 31, 2015 11:39 pm
Pmed about couple things. Thanks
hachirokufan
Postby hachirokufan » Sat Aug 01, 2015 8:23 am
You have like 90% of my wish list! Wish this came around next year when I will have the cash. Good prices guys!! Good luck with the sale!
illwillem
Postby illwillem » Sat Aug 01, 2015 8:54 pm
Parts sold, parts boxed up and ready to ship out- List updated.
previadrifter
Postby previadrifter » Sat Aug 01, 2015 11:49 pm
When I checked your blog and saw the car, I remember it for sale here in Oregon several years back. I'm not sure whether you have seen these threads or not, but here you go and the second one still has the pics up.
2011:
http://hachiroku.net/forums/showthread.php?t=26504
2012:
http://hachiroku.net/forums/showthread.php?t=30104
cedu
Postby cedu » Sun Aug 02, 2015 12:32 pm
Damn, Will. Lots of good **** man!
illwillem
Postby illwillem » Sun Aug 02, 2015 1:09 pm
previadrifter wrote:When I checked your blog and saw the car, I remember it for sale here in Oregon several years back. I'm not sure whether you have seen these threads or not, but here you go and the second one still has the pics up.
2011:
2012:
Yeah I saw those when I was doing research on the car before I bought it. When it showed up to me it was in horrible condition; much much worse than the pictures in the add even. As I was going through and pulling everything apart, little by little I realized that I was going to have to fix everything. It went from second fuck-around-track car to monster build in the space of a few days. I'm bummed that after all the work and hours into the car the situation is such that I'm not gunna be able to finish it, but it is what it is. :?
Calikid
Postby Calikid » Mon Aug 03, 2015 9:02 am
Hey pm me, want to buy a lot of parts....
illwillem
Postby illwillem » Tue Aug 04, 2015 10:32 am
Parts list updated. Lots still for sale.
illwillem
Postby illwillem » Thu Aug 06, 2015 9:42 am
Updated list. some new parts added.
ritz
Postby ritz » Thu Aug 06, 2015 4:20 pm
23 AE86 t3 brake master cyl brace, BNIB - $65
43 AE86 T3 BMC heat shield, black, new - $50
Color?
illwillem
Postby illwillem » Thu Aug 06, 2015 4:31 pm
ritz wrote:23 AE86 t3 brake master cyl brace, BNIB - $65
Color?
Black
ritz
Postby ritz » Thu Aug 06, 2015 4:36 pm
Color?
Black
I'll take that with 43 AE86 T3 BMC heat shield, black, new - $50
Price shipped to 94541?
illwillem
Postby illwillem » Tue Aug 11, 2015 10:55 am
Back from vacation, Stuff shipped out and new parts added.
ritz
Postby ritz » Thu Aug 13, 2015 12:11 pm
Bump for a legit seller.
Got my parts quick!
illwillem
Postby illwillem » Tue Aug 25, 2015 9:07 pm
Bump this up, parts shipped out, more for sale
henahito
Postby henahito » Thu Dec 24, 2015 6:14 am
Is your Kaaz 1.5 LSD still for sale?
Blade
Postby Blade » Thu Jan 07, 2016 2:46 pm
I'm interested in the rear brakes. My PM's don't work here, can you email me?
blaincox7@gmail.com
