Both the Tomei Poncams and the Toda adjustable cam gears are brand new, still in the box, never been used. The cams are drop-in for either the silvertop or the blacktop and will add about 15 HP. The adjustable cam gears are for the silvertop. I believe they fit the blacktop as well (the exhaust gear is the same but the intake gear timing is 5° different between the silvertop and the blacktop from factory, so the zero setting of this intake cam gear is in accordance to the silvertop).
Looking to get $580 for the cams, $260 for the cam gears. I'm in So Cal if you want to pick up.
PM me if you're interested. Pics upon request.
FS: Brand New In Box Tomei Poncams for 20v and Toda Adjustable Cam Gears for silvertop 20v
superpilunaw11
